Dzus type fasteners or something better?
Recently purchased a beat rush under tray made of full aluminum.. being that I’m going to be installing this soon I’m doing research on the best way to mount this. I’m looking for a lightweight durable quick connect type of setup. Any advice and specific links from people that have already walked this road? Thanks in advance!
I have the Beatrush Under Pan ...not installed yet but I did buy Dzus fastners from Pegasus Automotive. It seemed like the best choice
https://www.pegasusautoracing.com/ke...wordStart=dzus
The front piece is semi permanent. I don't see any need for special fasteners there. The rear piece has three speed nuts at the front. Those work okay. Just put 10mm speed nuts on the rear brackets and done.
Let me know what you end up going with. The link I found originally does not work anymore (no more part / out of stock). So depending on what works for you I will be right behind ya.
evotris
25
Jun 2, 2014 09:27 PM
Kreeker
Mar 11, 2013 06:18 PM
