In dash double din w ability to view Evo scan and listen to music/radio?
#61
I went with the Intel NUC because it can take a SSD and easily add RAM. I can also easily solder the power switch lead so that the pc can auto start/shutdown when the car turns on/off. The NUC is cheap used. Its still a very powerful little computer and good enough for a car pc. Also the double din is touch screen which is nice. I'm hoping the whole setup with weigh under 4lbs which is how much the stock radio weighs.
#62
Somebody re-cap all of this info. We have had a useful discussion here that is much needed. Do not let this thread die until we have got what we need. An in dash computer.. with a radio.. cd... dvd..Bluetooth..with a full running version of Microsoft Windows... completely compatible and up to date with the ability to run Evoscan with your tactrix cable plugged into the obd2 port and the usb end into the USB port on your carputer... I don't see what the issue is... no hacked up tablet hanging off the end of your dash... just a nice double din screen as big as we can fit
#63
Nah what needs to happen is either tactrix or evoscan or somebody needs to come out with an app that will run on Android and or Linux, because **** windows and that **** house Microsoft that it came from
#64
Your Buggin biggie... with all due respect. Windows is the way to go imho.... all the way back to dos.. simple. Easy. Unzip file. Call it a day.
#66
I don't want to derail this thread too hard with a wall of text, so I'll just make a claim from authority. I have 15 years of I.T./info sec experience and your wrong.
#67
I have quite a bit of IT background myself. I hear what your saying.. I get that Linux is loved by many..most career IT guys like yourself rave about it... for many years... I ran into the red hat guys in Vegas when my company sent me out for a data center seminar... but what we need is stability.. in choice of format... I believe windows or iPhone is a safe bet... but to each his own. I'll bow out out of respect.. I see you post all the time and your quite knowledgeable. All good.
#68
#69
I agree completely though that this shouldn't be so difficult to pull off, my own attempts at a Windows based tablet/evoscan solution failed, with probably close to 100 hours invested. The big problem is windows won't run on arm processors so you can't get a decent spec'd windows tablet for less then 500 bucks. Windows being so bloated it just doesn't run well on the lower cost stuff.
#70
I should have my setup running soon. Mostly just waiting on all the parts to come in to finish the project. When I finish I will try and write a detailed post. I’m still finalizing on the project so I don’t want to post till I get it all together.
#71
Lets not bring an OS Prejudice into this discussion. For the stated purpose of running evoscan on an in-dash screen, there really is only one choice.
That being said, I really like the idea of a NUC driving a touch screen. If that is a realistic option, you could run any OS you wish on it, Windows, Android x86, *nix, or even Hackintosh (assuming drivers are available for the touchscreen.)
I've been looking for a replacement to my old EVOScan GPS unit and so far no combination of device/os has been a suitable replacement. I've tried several combinations and the closest has been an old WinBook tablet running Win10; Unfortunately it is constrained by a 16Gb drive and slow performance. Unfortunately Hammish seems to have dropped support for EVODroid - never mind that it is half-baked and doesn't support flashing the ECU. I have an EVODroid and it is pretty clunky in comparison to my old GPSNav unit. I keep looking at http://e3io.com/carpc thinking I should just buy one of their units. Then I look at the price and think I can find a better solution
Looking forward to reading about positive progress on this idea
John-
Really curious about the components you chose for this adventure.
John-
#72
I kinda feel like a dick now so I'm going to get into the weeds a little bit here, op please forgive me. Linux and to a large extent android are embedded operating systems. They where designed to be able to be configured in such a way as to work with very specific hardware in a very stable fasion. All your devices are running *nix based operating systems. Windows is not, it's running all kinds of stuff that has nothing to do with what you are trying to do and there is no easy way to deal with that. You could go in and try and mess with the registry but because windows is not open source you will never have the level of control you have over what the OS is doing, or how it's using the hardware as you will with the *nix operating systems. Slowly over time windows is becoming more *nix like, because it's better. Also let's say you spend all that time making windows optimal as you can for your application, then Microsoft comes out with an update that screws all that up, and you basically have no options at that point but to start over. In *nix you have very fine control over every piece of software that is running and can choose not to upgrade some very specific thing that you need to stay the same, while still keeping everything else up to date. This is really just the tip of the iceberg but from a very high level one of the most important take aways is Microsoft is closed source, it's their playground that you have to work inside of, Linux is a playground that you get to design/choose every aspect of.
#73
http://www.defi-shop.com/products/sm...y_smart_adp_w/
Defi just came out with a "Smart Adapter" unit that interfaces between a standard OBD-II port and their link system and can wirelessly display the data on either an Android or iOS system. I'm looking at pairing it up with an ATOTO Double Din Android head unit from Amazon. The Defi App is free and allows for customization of gauge placement, unit type, colors, and warning values.
#74
Problem with that is its an iso-can device, our cars are pre canbus so the adapter we need has to support iso9141, and mut3 specifically
