View Poll Results: Should I replace the rings and bearings?
Yes, replace them
16.67%
No, leave the short block as-is
83.33%
Voters: 6. You may not vote on this poll
Is it worth installing new rings and bearings?
Hello fellow evo-ers. Long story short, my motor is out of the car because the transmission is getting rebuilt and I needed to replace the wiring harness. The motor is a stock evo 9 block with roughly 50k on it, the cylinder head is a stock evo 8 head that I had rebuilt (all oem parts) last year. The motor is on the stand, head is pulled as I will put all new timing components and head gasket on. My original plan to "freshen" up this motor was to pull the pistons, hone the cylinders, replace the rings, and replace the bearings. I've had mixed opinions and not sure if I should even bother or not. I don't plan to upgrade the rotating assembly or get any machine work done. The motor ran fine before it was pulled, I just want to help increase longevity at this point. The "build" will be mild and HP expectation is somewhere around 400hp. What do you guys think?
Pictures of your cylinder walls? Are cross hatches all there? I would look inside oil pan while engine is out and verify nothing is in there. Doesn't hurt to push on rod to make sure there is no play on any connection to crank.
Rings, pistons and cylinder walls all wear - its a system. So, when wear reaches the point where sealing is a problem all three must be brought back to spec. In fresh engines people have done drop in piston replacement. My opinion is that 50K is getting into the mileage range where this is no longer suitable.
Bearings can run 3 - 400,000 miles if the engine is taken care of or be destroyed driving around the block if the engine is run out of oil. Once a bearing fails and its metal travels throughout the oiling system its basically overhaul time if your goal is a permanent fix.
I'd suggest the best thing to do to maintain the engine is looking after fuel. Injectors don't last forever and need flow testing and maybe replacement after long service.
If you are into racing and competitive events, the engine should be looked on as a consumable just like tires or brakes and torn down, inspected and rebuilt at the end of each season or at whatever interval your use dictates.
If the motor makes good compression leave it alone.
I’ve got a bone stock 6 bolt bottom end that I’m putting in my galant vr4. The bottom end has over 300,000 miles on it. Makes great compression and leak down.
I believe In a old saying. If it’s not broke, it doesn’t need fixed.
PharmEcis
Aug 31, 2012 01:24 PM
33bull
Feb 11, 2010 08:54 AM
xspsi4
Aug 30, 2009 02:30 PM
STIKiller4G63
27
Feb 14, 2009 03:38 PM
