Small battery
Old May 16, 2019 | 05:28 PM
castro7's Avatar
Small battery
So I just did the small battery setup and works perfect but one thing I did not like is the positive cable it's kinda tight just want to see what you guys did to make a cleaner look and so on.
Old May 16, 2019 | 05:41 PM
hutch959's Avatar
my deka small battery has the post on the other side... looks like having to go across the battery is making it a little tight
Old May 16, 2019 | 06:04 PM
castro7's Avatar
Yea thats the only way i can do it i seen other ppl pics of the positive on the other side and the negative in the stock location but again i would need to stretch out the positive cable but how what are ppl doing to get it like that
Old May 16, 2019 | 06:36 PM
Terror Rising's Avatar
I stretched the harness while doing a mini-wire tuck. My positive post is up front and I never liked how tight it was. I'll take this sketch to work tomorrow and scan it but here's what I did. I ended up running new wire from the alternator power and the starter that was 12" longer for each. I added the length to the wire between the main loom and the battery connection.
Old May 16, 2019 | 06:49 PM
castro7's Avatar
Yea i like this look it looks super clean may i ask where you routed the wiring?
Engine bay is super clean also
Old May 16, 2019 | 06:51 PM
The routing for this harness is exactly the same as factory, just with extra length for the battery connection.
Old May 16, 2019 | 06:57 PM
castro7's Avatar
oh ok cool well looks like this is one option for me i like it man good job.
Old May 16, 2019 | 07:13 PM
Thanks man. This thread has a bunch of the supplies you need to reloom the harness when if you ever do it. Wire Tuck Thread
