Battery Relocation Stuff
#31
If you can find a spot directly on the frame rail that would be ideal. You can test resistance with your Meter between your chosen point and your battery chassis ground. You wan't basically 0 if you can get it, but the lower the better. While doing that you might find there is a better spot for your battery chassis ground then what is already there.
#33
Omg what a difference. I haven’t even started adding grounds yet. The car starts like never before. Idle sounds way better. Steady! Voltage at battery is now in the 14s. When I turn on ac and lights with fans on you can still hear idle drop though. I used 2 grounds at the battery. Spare tire and a bolt inside quarter panel. Both 2 awg wire.
#34
#37
Any ideas of good places to add extra grounds? Should I just replace the ones I can with thicker wire? If it helps at all I’d like to do it. It’s a night and day difference after I did all of this. I bet with extra grounds it’s be a lot better. I’m hooked!
#38
Yah i think thats right. What I did, and what I would advise you to do though is run another negative for the pump. If you upgrade the positive you also have to upgrade the negative. You are at an advantage having the battery so close to the pump, I would go straight from the pump harness connector to the battery chassis ground.
#42
Usually when you install aftermarket electronics you run new power circuits for them, so upgrading the alternator to fuse panel isn't usually necessary. It would be good to do though esp since your battery is relocated. Normally the fuse panel has a direct link to the battery, in your setup its at the end of a long daisy chain. During things like cold cranking and what not you could see a larger voltage drop at the fuse panel then you would if the battery was right next to it. In that situation a bigger cable would help. If you are going to bypass the factory fuse, you should add a fuse holder with your own fuse.
#44
So i am in process of doing this same thing I am just wondering if it can be done without the evo x fuse block can it be done with the stock on on the ix and if so what would be the best way to mount it any ideas ?
