Accident with a stupid deer
Old Aug 21, 2019 | 12:12 PM
EVOLUTION GRAND's Avatar
One night last week, hit a deer when coming home. Car was recently tuned. Wonder would there be any bad to the mods even after repair? Maybe power loss?
Old Aug 21, 2019 | 12:17 PM
Do i need to retune or redo alignment after frame repair?
Old Aug 21, 2019 | 12:26 PM
Oh Dang
If none of the intake members were changed w/another model, the tune should be just fine. The tune is held in the ECU and would not be affected by that IMO
Now, for sure on the alignment after an impact like that. Alignment should be part of the rework ticket
Hey, did the adjuster say anything about not having the crash beam in place?
Old Aug 21, 2019 | 12:49 PM
Oh Dang
I do not have full coverage, so... I'm buying new parts myself then bring it to a body shop to have them installed.
There is a certain amount of green fluid leaking after I hit the deer, but then no more leaks I can see so far. No significant change in coolant reservoir level, could it be ac fluid leak?
Old Aug 21, 2019 | 12:56 PM
heel2toe's Avatar
Ouch sorry to hear about this but glad youre OK. No need to worry about the tune; that'll be fine after the repairs are made. The car should most certainly be realigned after.
As for the green fluid its coolant and will most likely be coming from your radiator. The reservoir you mentioned is simply the spillover even with a bummed rad it wont necessarily drain that.
Old Aug 21, 2019 | 05:57 PM
Ok. thank you. I will ask body shop to check for any leaking and loose connections. My AC condenser is deformed now, but ac still works fine. Do I need to replace it? I have been unable to find a new evo 9 condenser.
Old Aug 22, 2019 | 05:29 PM
darrell's Avatar
Coolant leaking from the radiator and condenser u can get from Mitsubishi
Old Aug 22, 2019 | 11:00 PM
GTA.RS's Avatar
I feel your pain. In Aus, kangaroos love lit headlights. My front left light, bar and guard
Old Aug 23, 2019 | 05:44 AM
Biggiesacks's Avatar
You should replace the condenser, chances are the warped unit wont fit after they replace the radiator support. Just get an aftermarket one from Rock Auto or another parts place.
Old Aug 24, 2019 | 10:04 AM
That makes sense. I will get a new condenser. Thanks!
Bryson White
Nov 9, 2017 09:54 AM
Taro45
Oct 3, 2017 08:03 AM
sloAZevo
Jun 15, 2012 10:27 PM
kyoo
May 27, 2012 07:40 PM
loudneon
Sep 1, 2006 05:45 AM
