Throwing cam and crank cel after driving car hard around switchbacks
I was driving my car really hard around some tight corners with my buddies and when we got to the end my tac went to 0 and the car felt weird. I pulled over and it died when I threw it in neutral. Cranks but won’t start. Throwing p0340 and p0335 as well as a cylinder 2 misfire code which I’m pretty sure is unrelated. Any idea what happened? I’m guessing either one of the sensors went out or I jumped timing? Any advice helps
First thing I would do is pull top cam gear cover and verify timing marks. Visually inspect belt for excessive slack or and kind of damage. Maybe pull plugs to see what they look like. Check all IC pipes and vaccuum lines.
Not sure if it’s a needle bearing but it looks like one
It fell apart when I was wrestling it out of the car. It was defiantly destroyed when i popped the Cover off. Just not in pieces
This is the dent in the trigger plate
That pin came from somewhere, but I'm not sure where. Nothing under the cover uses anything like that. Do you run the run the car with both timing covers on, or is the upper not on it for some reason (which would allow foreign objects in)?
I have always ran all covers on timing area. Nothing seems out of place. I’m putting it back together wuth new parts and going to hope for the best
