Evo 6 lean condition
Am wondering if anyone has encounted this problem before,
one day my evo 6 just started loosing fuel when i would put the gas pedal down running as lean as 20afr. Idle afr started to get worse and worse and it will idle at 17-18afr at 43psi base pressure, i have bumped the base pressure up to about 60psi just to get a 14-15afr on idle.
things i have tried/ replaced:
Injectors
Fuel pump (dw300 hardwired)
Spark plugs
O2 sensor
Maf
Air filter
Fuel relays (including hardwire relay)
Tps
Intake/throttle body gaskets
Pump running 13.1 volts (battery had been sitting for a month)
ecu is a stock reflashed ecu with stock injectors/turbo/engine internals. Fuel system is a dw300 pump hardwired with a turbosmart 1200 fpr has a brand new fuel filter too
if anyone has any ideas it would be great as i have tried everything
Injectors
Spark plugs
O2 sensor
Maf
Air filter
Tps
Mauricio Evo IV
Apr 8, 2019 12:31 PM
evokid511
Nov 16, 2009 01:05 PM
