2003 Evo 8 Random Misfire P0300 [TSB Up to date]
City driving was fine, even under boost, but on the highway I threw p0300 random misfire and started misfiring around 70mph. If I let off and then on again it would be fine, but if I tried to keep a constant speed it would misfire. Read through the forums seen there was a TSB out for this common issue, decided to take it to the dealership.
Dealership tells me the TSB is up to date on my vehicle. So I’m really not sure what else it could be. Any help in the right direction is very much appreciated before the stealership drains me out.
2003 Evo 8 (previously had sat for more than a year without an engine/trans etc.)
- 77k miles
- ETS upper intercooler piping
- K&N typhoon intake (stock MAF)
- ACT HD clutch less than 1,000 miles
- Straight piped
- EGR delete
- APS BOV
- Everything else is stock and no other CELs aside from p0300 random misfire
- Spark plugs, ignition coils, all oils changed within 1000 miles
- 77k miles
- Straight piped
- EGR delete
- APS BOV
I would definitely be doing that as a first course. Boost leaks = vacuum leaks, and they both mess up fueling.
Will look into that thanks. With boost/ vacuum leak would I be getting the symptoms I described? Where I can boost and everything at low speeds but at highway speeds is where I get the actual misfire symptoms.
Small leaks effect low airflow volume like cruising the most.
Hey finally something I can post about! I too had this same issue (highway p0300 code). I did a ton of research on the problem and came to the conclusion that the HD clutch was the problem (I have the Exedy Twindisc HD). It creates a vibration that the ECU thinks is engine knock or misfiring and puts the engine into limp mode. It's not actually knocking/misfiring the ECU just thinks it is. The fix for it was to tephra mod the ECU and delete the p0300 code. I have not had a single code thrown since the code was deleted.
Ralliartize It
41
Jul 1, 2012 09:28 PM
