Thoughts on my build/ turbo thoughts
Old May 27, 2021 | 08:15 PM
raverthug's Avatar
I need thoughts on the build as a whole as well as recommendations for for a turbo. I currently have a MAP evo 9 turbo. I have thought of upgrading to an FP Black and would like to stay under $2500-3k if I change the turbo. This will be a toy. Highway pulls, airstrip attacks ect. I plan to run E85
Build
Map 2.0 stage 2
Non ported head
ARP L19 Head Studs
ARP Cam Cap Bolts
HKS 280 cams
HKS adjustable cam gears
GSC springs and retainers
JM Fab Fuel Rail
2200 injectors
BPR Single fuel pump hanger
525 Hardwired fuel pump
-8an feed -6an return
Transmission recently built by Jacks Transmission with carbon syncros
Exedy HD twin
Old May 28, 2021 | 04:27 PM
hutch959's Avatar
if you are going stock frame... any of the FP's are a good choice.
which one really just depends on you.
Old May 28, 2021 | 06:59 PM
raverthug's Avatar
Ok thank you. anything you see I might want to add?
Old May 28, 2021 | 10:20 PM
Evo9_Dubai's Avatar
Another affordable option would be to send out your turbo to Boost Lab and have them upgrade your evo 9 turbo to a 25g or stock frame 35r.
I have one still running on my friend's car since 3 years and it makes 440whp on pump.. On E85 it can definitely make 550 or more.
Nice choice for stock block and inexpensive upgrade compared to a FP or buying a new turbo.
Old May 29, 2021 | 04:27 PM
hutch959's Avatar
just depends on what you are wanting.
big numbers or a quick boosting street car.
your build looks good.
Old May 29, 2021 | 07:44 PM
raverthug's Avatar
Thank you. To be honest Im looking at random trips to Mexico and a fun car around town
Ill take a look thank you
Old May 30, 2021 | 04:13 PM
hutch959's Avatar
with that build... if it were me... (and i wanted to stay stock frame)
id be putting a FP Zero on it.
Old May 30, 2021 | 06:56 PM
raverthug's Avatar
I thought the black was the larges stock frame they made? Ill defiantly look at the zero a bit more
Old Jun 1, 2021 | 07:17 AM
schuhie's Avatar
We have very similar setups. I used to run an FP Green, was a great around town, almost stock feeling turbo with more up top. Made about 500hp/400ftlbs for a few years like that.
I recently built a high comp 2.0 and moved to a red. In my application, it is perfect. I spool almost the same as the green thanks to the higher compression but put down right about 600hp/500ftlbs on this setup.
I use my car for fun around town with some highway pulls and drag racing rolled in.
I personally would recommend the Red but like everyone else on this thread said, its up to you and what you want out of the car.
Highway monster = zero
street light to street light = green/maybe red
somewhere in the middle = red/maybe black
Go look at some dyno charts in the tuning section and see how you feel about the different boost curves and think through how you will actually use the car.
Old Jun 1, 2021 | 07:19 AM
schuhie's Avatar
One thing to note, the Green on a built bottom end would be an around town, low end torque animal.
Old Jun 6, 2021 | 08:29 PM
raverthug's Avatar
I ended up ordering the black as it will spool a bit quicker than the black
Old Jun 7, 2021 | 08:28 AM
RS200's Avatar
Old Jun 15, 2021 | 10:56 PM
raverthug's Avatar
Originally Posted by RS200
hahaha. I ment it will spool faster than the zero
Old Jun 16, 2021 | 06:46 AM
Abacus's Avatar
If you want to run it hard with E85 and its tuned well , these are some power numbers. Real Dynojet numbers using STD correction
If you want to make 575-600whp an FP red mhi works well for around town and top end. Around 20psi by 4000 on a mivec engine
For 650-680whp an FP Black mhi will spool up a little slower then the red but have more top end. Around 20psi by 4300-4500 on a mivec engine
The above MHI housing turbo's should go to 7500-8000 well.
The Zero is a badass stock frame turbo but will feel sluggish below 5-5500 around town since its larger and uses the SS housing. Should make 740whp + It should go to 8000-8500 well.
I personally think a mivec 2.2 red mhi works well Or a 2.3 mhi black for a fun well rounded car.
Power is easy on these cars, keeping the transmission happy with high rpm shifts is another.
raverthug
23
Jun 30, 2020 09:25 AM
LimitlessEvo7
27
Jan 12, 2018 12:36 PM
ExtremeEvo
Nov 26, 2014 04:10 AM
rmorr79
Mar 14, 2013 10:57 AM
kamakazy_kid
Aug 29, 2012 06:00 PM
