No power to AC pressure switch!
Old Jun 16, 2021 | 07:50 PM
Jacobt's Avatar
Can anyone shed a little light on how the power should run from the relay to engage the clutch in the compressor? I replaced the compressor since the old one wouldn’t engage and it was worn out. It never worked and now I’m finding out I didn’t have power to the pressure switch to even kick it on. Tried vacuuming down and adding Freon but still won’t get power.
Old Jun 17, 2021 | 04:51 PM
hutch959's Avatar
got to be the ac relay... right?
Old Jun 17, 2021 | 06:25 PM
Jacobt's Avatar
That was my initial thought as well but swapping it out for another known good relay didn’t do the trick.
Old Jun 18, 2021 | 04:26 PM
hutch959's Avatar
you check the continuity on all the wiring?
should be easy to do using the wiring diagrams.
Old Jun 19, 2021 | 01:29 PM
barneyb's Avatar
The magnetic clutch gets power from the refrigerant temperature switch which is part of the compressor. The temperature switch gets power from the switching side of the A/C relay. The switching side of the A/C relay gets power from fuse 9 in the relay box (evo 8). The control side of the A/C relay gets power from the ignition switch by way of fuse 5 (evo 8) on the junction block. The coil in the control side of the A/C relay is activated (relay is closed) when it has a ground supplied by the engine ECU. The blower switch, inlet and outlet thermo sensors, the outside air damper and the A/C controls are connected to the A/C ECU. The A/C ECU has two wires that connect to the engine ECU, one through the pressure switch. So, when all is right with the world, the engine ECU supplies a ground, the A/C relay closes and the system runs.
Old Jun 19, 2021 | 04:00 PM
hutch959's Avatar
very nice...
Ude Lose
Aug 6, 2019 03:26 PM
S3CR3T
Jun 14, 2013 06:15 PM
adcgn45
Sep 23, 2012 07:25 PM
fantrman
13
Jun 6, 2012 07:48 AM
JSYEVO
Jun 7, 2005 02:00 AM
