Cold Start Oil Pressure (Evo 4)
Hello,
Hope that every one is doing fine and great !
I started my car after 2 days today. I noticed that my cold start Oil Pressure is around 32-35 Psi . Oil i am using Liqui Molly Mos2 10/40.
The car has its Idle control valve removed so when cold started the car idles at 1k rpm ( could this be a cause Bcoz on my civic with idle control valve , on cold start its rpm is around 2-3k) .
When warmed up idle oil pressure is around 13-14psi (which is under spec), during boost the oil pressure goes to around 110-120psi.
Should i be worried about this ? Should i change to some other oil ? Should i get the idle control valve installed on the car ?
Any help will be greatly appreciated. ( I am running stock boost / stock engine etc)
roni4g63
15
Dec 27, 2016 09:08 AM
