Crud, that might have cost me 2k
Old Dec 20, 2021 | 09:46 AM
WalkerWakaWaka's Avatar
5 Year Member
I had my clutch replaced a month ago and I gave them Trans oil and ACD oil. I didn't give them Transfer Case DiaQueen oil as I didn't think they would need it. Now my TC is dead and I am sending it off to Shep to rebuild. They stated they didn't drain the TC but when I pulled the plug on it, I am pretty sure I saw red in with all that black metal which used to be my TC.
Is it common to loose TC oil in replacing the clutch? I am thinking you have to remove that stub shaft from the drivers side of the trans which goes into the TC so I suspect it would loose a lot of the TC oil and someone topped it off with ACD fluid.
Do you loose TC oil when replacing the clutch?
Old Dec 20, 2021 | 10:18 AM
ViciousLSD's Avatar
Yes
Old Dec 20, 2021 | 03:33 PM
Jonno99's Avatar
The fill hole is higher than the tail shaft. You pull the tail shaft, then what's going to happen. Yesterday I had mine up on the jacks replacing the TC oil. As an Evo owner it's important you spend time under the car understanding how things go together. There is a lot of maintenance you can do yourself, otherwise make sure it goes to an evo knowledgeable mechanic who will write a list of the things he is doing and you get to agree on it before the work starts.
Old Dec 21, 2021 | 09:21 AM
LetsGetThisDone's Avatar
I don't drain the TC when doing the clutch. No need to.
Old Dec 21, 2021 | 09:39 AM
5 Year Member
When you pull the intermediate shaft (think thats the name) which connects the transmission to the TC, wouldn't you loose TC oil?
Old Dec 21, 2021 | 04:41 PM
hutch959's Avatar
no...
im sure they pulled the drive shaft out and it ran out.
Old Dec 27, 2021 | 09:11 AM
Dallas J's Avatar
Veteran: Army
The oil that comes out when you pull the intermediate shaft is trans fluid. Its always worth checking T-case oil when you take stuff apart but shouldn't need any after just a trans removal.
Old Jan 22, 2022 | 12:57 AM
aldonkaka6's Avatar
hi
no...
turkish citizenship
I'm sure they took off the drive shaft and it wore out.
Jonno99
Jul 16, 2017 05:59 PM
m0nkie
Nov 19, 2014 01:54 PM
IAmADirtDude
Nov 27, 2012 06:49 PM
Emperor666
17
Jul 21, 2008 10:58 AM
dean evo9
11
Sep 19, 2006 10:41 AM
