Evolution compression numbers
Old May 1, 2022 | 02:50 AM
Seto519's Avatar
My compression numbers are 120/120/90/120 without stepping on throttle and car warmed up. Are those numbers bad? I’m pretty sure cylinder 3 is bad since it’s off by 30, so I’m going to do a leak down test on it to see what’s wrong. Is 120 considered low for the other 3 or if it’s ok? Car has 160k miles, got it last year never drove it or done maintenance on it yet. This is for a 9 if it makes any difference
Old May 1, 2022 | 06:46 AM
Tim M's Avatar
5 Year Member
One should have full open throttle when doing a compression test and fully charged battery.
120 seems very low...my fresh Evo 6 engine does 190's.
Old May 1, 2022 | 08:30 AM
RallySport9's Avatar
I think evo 9 is supposed to have significantly lower compression numbers, but not that low. ^ Do this and try again.
Old May 1, 2022 | 09:30 AM
Manual notes here:
Old May 2, 2022 | 04:31 PM
hutch959's Avatar
9 compression test are always low due to the mivec
you got stock cams?
Old May 2, 2022 | 11:21 PM
Seto519's Avatar
i did read that 9 compression are lower, but 120 sounds kinda low. i also saw others with 9 are aound 150. car is all stock. i am re doing my compression test this weekend with the throttle fully opened and hopefully i'll see better numbers
InitialE
Sep 20, 2021 05:24 PM
mr2rr
10
Apr 22, 2015 11:05 AM
MrHouse
Jun 10, 2014 10:56 AM
06EVO22
Mar 27, 2012 06:50 PM
Enzo1089
56
May 19, 2010 06:25 PM
