Rear Window Frames - Rusted (IX)
Old Apr 4, 2023 | 10:38 AM
True Blue's Avatar
Unfortunately the doglegs on my rear windows have rusted at the base of the trim where it meets the horizontal beltline trim. (excuse the pollen, it's April in the south)
Not entirely certain what I'll find once I dig the tape off of these but it'll be nothing good.
I've found a few links that help me remove the front trim, including the satin black door tape:
https://www.evolutionm.net/forums/ev...ding-trim.html
https://www.evoowners.co.uk/threads/...#axzz3A48Vh1Vq
https://stmtuned.com/products/mitsub...r-tape-evo-8-9
https://www.ebay.com/itm/385275758799
and even a vid
I'll probably grind off the remainder of the rot and POR-15 the remainder, bondo inside if needed. Once the new door tape's there it should be protected.
Any notes on removing the rear trim? I've found all sorts of front but nothing about the back door window.
Thanks all
Old Apr 18, 2023 | 10:50 AM
True Blue's Avatar
Bump. I'm purchasing the "tape" for the frames. Nobody's run into this before?
Old Apr 18, 2023 | 12:04 PM
RallySport9's Avatar
The se tape? It's just decal not sure it would help with rust. Crazy these cars are old enough to where they're rusting there. Weird to see.
Old Apr 19, 2023 | 05:27 AM
mitsuatb's Avatar
Find another door that is from an arid climate and get it painted. I don't think repairs in that area are going to work well.
Old Apr 19, 2023 | 12:42 PM
True Blue's Avatar
Strangely it's just the upper door frame. The bottom of the doors by the weep holes and pinch welds are fine. And it's on both rear doors, so it's unlikely it was something just plugging a drain as it's in the same spot in two areas. : /
Old Apr 19, 2023 | 12:47 PM
deylag's Avatar
I would sand it down and use an expoxy based paint to seal it up. I wanted to remove the trim vinyl and repaint it gloss black anyways.
Old Apr 19, 2023 | 12:52 PM
True Blue's Avatar
Pretty close to the plan - but I'm going to treat the inevitable holes and cavities with POR-15 and putty smooth. Once the tape's on it'll cover most of the imperfection - I just don't want any further rot once it's sealed.
Damn curious as to where the water ingress came from.
Old Apr 20, 2023 | 10:24 AM
Kevin.'s Avatar
I have the same thing on one side rear window
Old Apr 20, 2023 | 12:05 PM
True Blue's Avatar
Out of curiosity, did your car see any salt? It's awfully high up to be sprayed by road splash but I wonder if that's where it comes from.
Old Apr 21, 2023 | 10:53 AM
Kevin.'s Avatar
yea, PA - probably the worst state in the nation
Sleepless
Jun 1, 2018 01:56 PM
ct9asilver
Jun 24, 2016 03:33 PM
AWDPowah
11
Feb 15, 2010 10:16 AM
EVOIX_LMS
Nov 15, 2007 08:20 AM
