Installing ETS battery kit - stupid question
Old Jul 24, 2023 | 06:24 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
So the OEM battery tray has the 4x 12mm bolts, and 1x 10mm bolt. The 10mm is holding on this little metal plate ^ behind my thumb in the picture.
Can I remove this plate entirely? Does it serve any grounding purpose or is it just to keep the wires from flopping around?
Thank you!
Old Jul 24, 2023 | 09:49 PM
ViciousLSD's Avatar
Yes. you might want to unbolt every cable from the fuse batt terminal and straighten/route them.
is that your new 5sp transmission?
Old Jul 25, 2023 | 12:15 PM
Butt Dyno's Avatar
Thanks! OK, I can clean this up today then.
Yep! I only have like 150 miles on it and I'm kinda missing the six speed from a street driving perspective, but not grinding 4th gear is nice.
Old Jul 25, 2023 | 12:25 PM
ViciousLSD's Avatar
I thought a TRE built trans would look fresher
It would look cleaner without those wire loom thingers on single cables too
Old Jul 25, 2023 | 04:44 PM
Jp7's Avatar
Jp7
I have a spare set of mini battery terminals if you need them.
Old Jul 25, 2023 | 05:44 PM
amoeboids's Avatar
Okrs
🎉Are you tired of setting goals that fizzle out? Say hello to OKRs (Objectives and Key Results) and experience a transformative change! 🌟 Benefit from increased motivation, focus, and measurable outcomes. Start crushing your goals today! #OKRs #Motivation #GoalCrusher 👍
JDavenport
Oct 29, 2013 12:32 PM
kim.ry
Feb 20, 2011 07:11 PM
06RedRalli
Mar 24, 2010 06:34 PM
E85evo8
May 15, 2009 03:02 PM
11secMR
14
Oct 30, 2008 03:18 PM
