Evo 9
Old Apr 29, 2025 | 12:01 AM
Adbraxx's Avatar
Evo 9
Hello, after a bit of driving my evo transmission won’t go into gears or shifting gets unusually hard, I bleed the clutch, transmission fluid is full. Usually reverse and first gear sometimes all gears by the way it’s a 5 gear transmission with a almost brand new atc twin disc clutch thank you in advance
Old May 1, 2025 | 07:44 AM
High_PSI's Avatar
Time for a rebuild. Check your Slave cylinder. Could be your clutch failed as well.
Old May 8, 2025 | 12:51 AM
Adbraxx's Avatar
I replaced the slave and master cylinder no help. Do u really think it’s time for a rebuild?
Old May 20, 2025 | 06:07 AM
.michal's Avatar
You need to open and see if there are no loose parts inside
Old May 20, 2025 | 07:43 AM
Geforce_EvoIX's Avatar
syncros might be going ..
"Failing syncros in a manual transmission can manifest as difficulty shifting gears, grinding noises during shifts, or slipping gears. Other signs include a burning smell, especially if the transmission fluid is overheated, or a grinding noise between gear changes"
Old May 20, 2025 | 08:58 AM
CurseDSM's Avatar
Or maybe adjust the clutch properly. It's out of adjustment if he has a newer twin disc.
Old Jul 9, 2025 | 10:59 PM
Adbraxx's Avatar
you are right I might have to open it up. Btw the issue is intermittent. It came back today
Old Jul 9, 2025 | 11:00 PM
Adbraxx's Avatar
there isn’t any grinding also it starts with one or two gears and then it’s all it’s an intermittent issue it came back today
Old Jul 9, 2025 | 11:01 PM
Adbraxx's Avatar
do you mean pedal height adjustment? Or something else btw it’s an intermittent issue it’s came back today
Old Jul 10, 2025 | 08:48 AM
CurseDSM's Avatar
No the pedal adjustment. I forgot to tighten the nut on mine last time I did the clutch and it acted up for a while until I was like oh yeah check that lol.
Mellon Racing
176
May 30, 2017 05:45 AM
Rom
Sep 10, 2014 04:32 PM
Harumsevo
Jul 30, 2013 05:19 PM
elijahcole92
17
Oct 19, 2009 11:46 AM
Go Trees
Jun 23, 2004 09:33 AM
