Evo 8 breaking up in boost!
Old May 18, 2025 | 08:07 PM
Jdmbart's Avatar
Hello all, I have a 2005 evo 8 that is breaking up as soon as I try to hit boost.
I just car the car tuned and AFRS are great, it actually started breaking up halfway throug the tuning sessions around every other run. Now a few weeks later it breaks up much more often.
Fairly simple e85 setup, id1050x, aem 340 pump, evo 8.5 turbo, 272 cams, intake, exhaust.
I have boost leak tested it at 30psi and fixed all leaks, no more boost leaks. Plugs are new and gapped at .20, new Omni map sensor and all 4 denso coilpacks.
Any thoughts on what it could be? TIA
Old May 18, 2025 | 11:53 PM
Luca Bernardi's Avatar
When it cuts, do you have an AFR drop?...try clean the MAF sensor or air filter, maybe it reads wrong and cut for safety
Old May 19, 2025 | 05:49 AM
Jdmbart's Avatar
I believe it drops, I actually did recently clean both lol, issue still remains.
Old May 19, 2025 | 06:08 AM
Vacuum line of WG? Blow-off?...are you able to monitor the fuel pressure?
Old May 20, 2025 | 06:57 AM
M4Lki3r's Avatar
Veteran: Marine Corps
Check your coils? I had one going bad and it was causing misfires under boost.
Old May 20, 2025 | 07:37 AM
Geforce_EvoIX's Avatar
Plug gap might need to be .24.. mine are .18 but I'm running more than you, check you're not losing fuel pressure when hitting boost. Tuner should have caught that you're going lean and assisted in finding the problem. Like someone else said, Denso coils, they're not highly liked for evos from what I've read.
AussieAirtrek
Jan 12, 2023 07:11 AM
Countrystrong11
Aug 26, 2011 04:31 PM
RedLanEVO
Sep 30, 2007 04:26 PM
Caseman2
Aug 13, 2007 12:00 PM
EvoDaWayToGo
AEM EMS
Jul 1, 2005 01:20 PM
