MAP Sensor
Old Jun 23, 2025 | 12:09 PM
NorEvo's Avatar
MAP Sensor
Not too long i got myself an evo 9. The car is running perfectly, but i recently noticed that my MAP sensor is not connected. The sensor is there but no cable.
Should not the car run bad/throw check engine light? Any reason to not run it connected?
Old Jun 23, 2025 | 01:41 PM
schuhie's Avatar
MAP or MAF?
If MAF, probably has a speed density tune and someone didn't replace the intake piping.
If MAP, I have no idea. It should cause tons of issues with all sorts of drivability and stuff if it isn't plugged in. Its possible they are using a different MAP connected somewhere else on the intake manifold?
Old Jun 24, 2025 | 12:38 AM
NorEvo's Avatar
Old Jun 24, 2025 | 06:01 AM
schuhie's Avatar
Man, that's weird. I would start chasing the harness looking for where that plug is now. It seems possible that there is an aftermarket MAP somewhere and that's what is plugged in and what it is using.
I'd start by checking where all the vacuum lines on the intake manifold are going, if there is an aftermarket MAP, it has to be connected to the intake manifold somewhere.
hyeteck
Jul 16, 2011 03:56 PM
vroomevo
Jan 7, 2007 08:10 PM
