Gauge cluster lights failing?
Old Apr 18, 2011 | 10:10 PM
  #61
barneyb's Avatar
Originally Posted by Unrivaled
My bulbs worked fine but I wanted to replace them with LEDs and pulled out the left and middle one to see the sizes, put them back in and they don't work anymore. Anyone have any ideas?
I wanted to remove the blue condoms. What I learned was that if you touch the bulbs they are toast. Any movement breaks the filiment of used bulbs. You need some new ones.
Old Apr 18, 2011 | 10:47 PM
  #62
Unrivaled's Avatar
Bah I guess they had to save money somewhere in production , thanks for the info mate.
Old Apr 19, 2011 | 03:43 AM
  #63
bigben's Avatar
http://www.mitsubishiparts.net/catalog/?section=1078
Old Apr 19, 2011 | 07:52 AM
  #64
Blue95GST's Avatar
Seems to be a common problem, I would recommend led replacements
Old Jan 6, 2013 | 10:30 AM
  #65
islandct9a's Avatar
I know this is a old thread but thought that I would let everyone who was involved in the write up know that it was very useful.
Old Jun 6, 2015 | 07:13 PM
  #66
flyineunos's Avatar
I want to bump this thread, where do i find LED replacements? Anyone have a part/model #
Old Jun 14, 2015 | 09:37 PM
  #67
Adamsturbosma's Avatar
^ would be helpful with the led PNs... my left side goes in and out intermittently.
Old Dec 29, 2015 | 09:03 PM
  #68
jturby's Avatar
Bump, looking for how-to on replacing the bulb on the temp gauge in my 06 GSR
Old Dec 29, 2015 | 09:26 PM
  #69
barneyb's Avatar
I think there are two screws up under the dash lip. Remove those, drop the column and tip the cluster top towards you. Unplug the two harness connectors and place the cluster face down on a clean towel - the bezel scratches easily. On the back the bulbs twist out.
You should have a replacement bulb in hand plus a couple of spares before disassembly. Fix one and find the next one is out.
I don't understand the blue condoms on the OEM bulbs. Remove them for much better illumination.
Old Dec 30, 2015 | 06:22 AM
  #70
rogerlam's Avatar
Easiest way to take the cluster out is by pulling out your plastic trim where your mirror and ACD switch is.
LED parts are 3x T5 neo wedge for the tacho, speedo and temp.
1x 74 LED for the ODO,
If you want to do all your other switches while you're at it, you can use the 74 LED for your HVAC, cigarette plug and ash tray.
For JDM climate controls the LEDs are either T3 or T3 neo wedge.
For the ACD, headlight adjustment and foglight switch there is no part number for those, you can pull out the stock bulb and put in LED bulbs and use the stock housing, otherwise the closest part is T3 neo wedge.
Old Jan 4, 2016 | 01:46 PM
  #71
flyineunos's Avatar
Thank you, this is what i needed!!
myra13
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 16, 2017 07:26 PM
VicVoss
Sep 28, 2016 06:37 PM
Lombardi23
Apr 30, 2016 01:03 PM
Nick Vargo
Jan 6, 2016 11:01 AM
Cyrax91
Jan 2, 2016 12:59 PM
