Camshaft Position Sensor
Old Aug 19, 2004 | 10:28 PM
MitsuJoe's Avatar
I have searched and looked in the service manual for the part # of the Camshaft Position Sensor. If you didn't know this is the sensor mounted on the front right side of the head which is right next to the upper radiator hose. It is supposedely a commonly broke piece when installing BOV's and CAI pipes.
Thanks for your help!
Old Aug 19, 2004 | 10:30 PM
MitsuJoe's Avatar
BTW I pulled this same sensor out of my girl's 04 Ralliart and it was almost identical although the probe part (goes into the head) had some lines and dots on the shaft part.
The sensor from the EVO has a completley smooth shaft and a little dot on the blunt end of the sensor. I also noticed the sensor was magnetic. It stuck to my metal shelves when I tried to half-**** fix the broken sensor.
Old Aug 19, 2004 | 11:11 PM
MitsuJoe's Avatar
pic
I snapped a pic of the broken sensor...a little blurry
Old Aug 20, 2004 | 12:34 AM
erioshi's Avatar
The service manual doesn't list a PN. You may need to contact a dealer to get the number.
Old Aug 20, 2004 | 12:37 AM
MitsuJoe's Avatar
yes I will be doing that in about 4 hours...
Old Aug 20, 2004 | 06:55 AM
EvoJimbo's Avatar
Look on the broken camshaft position sensor. It should have the part number on it.
Old Aug 20, 2004 | 08:26 AM
MitsuJoe's Avatar
MD327107 is the part #
On the sensor it doesn't have the part #, more like a production #.
batty200
Apr 22, 2014 05:11 AM
Graphic
10
Oct 24, 2011 10:37 AM
DSMMR21
Jun 26, 2011 11:08 AM
rino
14
Apr 1, 2011 11:37 PM
nefblkevo
Mar 19, 2007 04:18 PM
