-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   I installed a Helix 3" downpipe and it's making funny noises!! (https://www.evolutionm.net/forums/evo-general/123583-i-installed-helix-3-downpipe-its-making-funny-noises.html)
03silverevo8 Feb 18, 2005 09:24 AM
I recently put a Helix 3" downpipe and i notice a weird noise under my car, I think it might be rubbing against the lower sway bar. But does anyone else have that problem??
DaveWhiteEvo Feb 18, 2005 09:29 AM
mine was hitting the k-member. had to mark the down pipe and perform the "custom no rub" mod with the hammer. i just flattened it a few mm's and no rubs.
BajasMR Feb 18, 2005 10:08 AM
Mine does the same thing!!! argghh its annoying.:mad:
YellowFever Feb 18, 2005 10:11 AM
if u did that - ur car must handle like ish now :p
nick735 Feb 18, 2005 10:12 AM
Mine helix dp has no rubbing issues whatsoever.... Do you guys have version 1 or 2?
PHiSH Feb 18, 2005 10:17 AM
Mine doesn't rub at all either. I've got the newer version though.
nefblkevo Feb 18, 2005 10:22 AM
Same issue
I posted a similar thread on SoCalEvo. I've got a 3" Helix dp and i have an annoying vibration that I feel through the foot pedals or floor boards. mostly at idle or initial take off or perhaps shutting the car off. I don't have any rubbing issues and it's not hitting anything but its installation has somehow increase the vibrations that i feel in the car. i mean its not really bad but it does annoy me. i'm wondering if there is anything that I can do to make it go away.
redevo561 Feb 18, 2005 10:26 AM
check how the downpipe connected to the 02 housing if its not on right it will sit on a angle and throw off your hole clearance and will give you vibrations and noises
superman105 Feb 18, 2005 10:28 AM
I have version 2 and it rubbs when it's cold especially in the morning.
only in 1st gear and revers
recently I just wrapped it with Termal-Tec warp
and the noise is gone !
Evoisdream Feb 18, 2005 10:35 AM
when mine was rubbing it was beacuse i didnt install the downpipe first i put the downpipe and rest mainly together off the car so i just went under and adjusted the downpipe and put it back on made sure it went on even and it has yet to touch...
DaveWhiteEvo Feb 18, 2005 11:03 AM
Ummm...i didn't beat the k-member, i beat the dp. but i seriously hope you were kidding? ;)
03silverevo8 Feb 18, 2005 11:24 AM
03silverevo8
Thank all of you who wrote on here. I am gonna see if everything is lined up straight with the O2 housing and the downpipe,I hope the rattling noise stops!
03silverevo8 Feb 18, 2005 11:28 AM
03silverevo8
I dont know which version I got? My friend gave the Helix downpipe to me for free so I thank him for that and now he got a 2.75 downpipe cause that noise thing with the 3" thats why he gave it to me. The Helix downpipe doesnt have that little flex part on there if that helps which version I got??
03silverevo8 Feb 18, 2005 11:29 AM
03silverevo8
I heard that when you get a test pipe on your car it will throw check engine codes!
Volunteer Feb 18, 2005 11:30 AM
My Version 2 rubs on the frame tunnel. I made custom spacers with some poly bushings for both cross members because I though it was rubbing there. I need to do the hammer trick too, I just hate the risk of cracking it. :mad:
