All Part Number Request Go Here
Hi guys,
this will be the thread to request differnet parts #s. please do not go OT in this thread because all off- topic posts will be deleted and the users will be warned. thanks Snir EDIT: timzcat Here are all of the part numbers to this point. Please check here first! For people supplying part numbers, please try to format it as number description as below. It will make my life a lot easier when updating the list. Thanks Body/Interior/Exterior MR633538 Upper Steering column cover MR572609 Board, trunk room floor MR444269 Trim, Trunk room RR end (Grey) MB547806 Clip, Engine Room Cover MD569372 air intake rivet MR288876 hood vent rivet MR975089 coin box MN126274 Insulator, Hood MZ598263 CD Changer Install kit MR626799 cd changer panel only, no rails (black) MU480007 licence plate grommet (square) MN168249 Gear Shift Lever Retainer (part of the gearshift level) MR286178 Replacement trunk lock MR633547 panel with the shifter and ashtray and the cigarette lighter MN161463 RS ~04/07/31 trunk lid MN161464 RS 04/08~ trunk lid (no spoiler) MN150620 RS 04/08~ trunk lid (spoiler) MN161462 MR trunk lid (spoiler) MN161463 MR trunk lid (no spoiler) MR574731 front Mitsubishi symbol MR975477 intake/trunk carpeting fastener MB547806 front undertray fastener MB918617 ashtray light MR412407 RS trunk bar MN101890 MR bilsteins Fronts MN101899 MR bilsteins Rears MR647677 the piece that holds the ashtray and the cig lighter MR970228 black RS door handles Front Right MR970227 black RS door handles Front Left MR970268 black RS door handles Rear Right MR970267 black RS door handles Rear Left MR250558 Radio delete panel MR627152 interior door handle Front Left MR627153 interior door handle Front Right MN161534 rear side marker light MR648031 rear interior door panel (which side?) MR973540 antenna Base MR583214 antenna Nut MR587268 stock radio (evo?) MR506482 headlight height adjustment switch MN126920HB 3rd stoplight cover (You have to get the whole light assy.) MZ380295EX vortex generator MR962799 03 Evo's clock MR512557 plastic housing arount the clock and hazard switch MR954150 Right (Passenger Side) Front Fender MN161172 Right (Passenger Side) Complete Entire Light (Including Housing, HID) (this is the entire assy.) MR954176 Right (Passenger Side) Front Wheel well Plastic Dirt covering MN161277 Hood MS240129 Bolts for gas tank and rear trunk tie bar MR572500 Clips for the rear trunk liner MN151260HA MR Mats (both sides?) MN126980 Front bumper undertray MN161109XA Black front bumper cover MN101464 MR Front springs (same part # as GSR/RS) 4140A007 MR Rear springs MR538851 Fog Light relay MN126784HC Lower lip of front clip (comes pre-painted) MN126771 intercooler grille MN126979 Left Undertrays w/ brake cooling ducts MN126980 Right Undertrays w/ brake cooling ducts MR379950 Center Undertrays w/ brake cooling ducts MN126784 HC (Pre-painted) EVO8 FRONT AIRDAM LIP MN126981 PANEL UNDERCOVER FRONT MN126979 PANEL UNDERCOVER FRONT CENTER MZ530857 Mud Flap Kit Carbon (Evolution) MZ530855 Mud Flap Kit - Red (Ralliart) MR109421 diamond trunk badge for a 1999 Galant. MR631941 Left a-pillar MR631943 Right a-pillar 8011A017 MR Sticker MR795453 02 lancer 0Z switch blank cover MR573539 02 lancer 0Z Plastic Tabs that go in door handles (left) MR573544 02 lancer 0Z Plastic Tabs that go in door handles (right) MR627179 02 lancer 0Z Plastic Trim Ring for Passenger Side Rear Door Handle MR497518 02 lancer 0Z Air Intake Ram Air Piece MR233903 USDM cigarette lighter MR506482 USDM headlamp tilt angle switch MR627178 02 lancer 0Z Plastic Trim Ring for Driver Side Rear Door Handle MN161109RA Rally Red Bumper Cover MN126784RA Rally Red front airdam lip Metal mounting tabs that secure the mesh grills to the bumper: MB325298 10 pieces needed MR447202 2 pieces needed MN161109WA White bumper cover MN126784WA White air dam MS820976 fog light housing the e-brake handle/assembly (not the cable, just the knob and rubber boot). MR628249 w/ a build date from 1Dec02-3Dec03 MN102750HA w/ a build date from 1Jan04-3Jul04 MN102750HB w/ a build date from 1Aug04-Present MN126723WA Front bumper cover section (small painted piece, white): MU488006 Front bumper clips MN150450 Right Rear Door Shell MR647677 Console panel around Shifter (grey) MN151264HA Radio and Climate control Panel MR500935, MR500932, MR568314 Climate control labels MR644580 04 RS Front Left A-pillar panel (no tweeter) MZ690125 & MZ690130 Front blades: MR538217 Rear blade: MR417280 Dead Pedal MR206570 Dead pedal Cap MR646881 Ash tray door MR973541 Antenna Mast MR973540 Antenna Base MR583214 Antenna Nut (2 needed) MU488006 Upper bumper clips cooling area MR626743 Defroster garnish (panel up by windshield across dash) MR647724 Front license plate bracket MR627159 Left front kick panel (next to dead pedal) MR633500 Right front kick panel MR538216 '05 MR Rear Wiper , without the motor (This is the arm only) MR973541 '05 MR Antenna 6370A205 '05 MR Trunk Key Lock MR654028 '05 MR Passenger door Key Lock (Includes handle) MN126530 '05 MR Hood Mesh only MU488006 Clips into the bumper cover for cooling shroud MR200300 Clips into the radiator support for cooling shroud MR513027 Recirc door assembly for HVAC MR548949 Roodf skin No sunroof MR548950 Roof skin W/ sunroof MR633889 Armrest lid (suede) with hinge Drivetrain/Chassis/Suspension MR232147 Gear link bushing MF247868 (1) MF140210 (3) MF140206 (6) Cam cover bolts MD050316 Oil drain plug MD569372 M/T plug MZ690116 oil filter MR552951 air filter MR407376 Front pad kit (hardware sold separately) MR407391 rear pad kit " " MD979313 water pump MN158794 alternator belt MD186785 spark plug grommets MD340535 valve cover gasket MD152772 pcv valve MN132206 clutch disc MR980846 pressure plate MR145619 T/O bearing MD746617 clutch slave cylinder MR491945 clutch master cylinder MN149074 crankshaft pulley MR370723 front brake rotors MN153010 oxygen sennsor frt MR578532 rear oxygen sensor MD327107 cam position sensor MR578117 knock sensor MD363552 ignition coil MD343245 plug wires set MD374841 spark plugs MR984375 timing belt adjuster MD369999 timing belt pulley MN153356 BODY ASSY,AIR CLEANER (Stock Airbox) MR578399 SENSOR,AIR CLEANER (MAF SENSOR) MN153284 Diverter Valve MR475929 Left caliper MR475930 Right caliper MD160689 1G Air bypass valve (for anyone using Buschur upper IC) MN143213 stock boost solenoid located under the airbox MD372536 cam seals MN158794 Alternator and other drive belt MN153284 MR bypass valves MR450703 donut gasket for the downpipe MR481252 radiator cap MR597271 downpipe bolts MR597273 downpipe Springs MR497545 studs on the cat MR571083 downpipe -> cat (nuts that go on the studs on the cat) MF241309 cat -> cat-back bolts + nuts 1545A001 MR BOV MD345681 Rocker cover center cover MD000312 transmission drain plug gasket MF660036 transmission fill plug gasket MD000312 transfer case drain plug gasket MD000312 transfer case fill plug gasket MB001294 rear diff. drain plug gasket MF660036 rear diff. fill plug gasket MR580533 teflon shifter cables MR MN107670 teflon shifter cables GSR/RS MN143079 timing belt cover lower front MN153353 Air Cleaner box cover (top) MD613573 MR Specific Compressor housing MD613524 MR Specific Turbine housing MD613567 GSR/RS Specific Compressor housing MD613521 GSR/RS Specific Turbine housing MN155744 Cyl Head MN143619 Intake Camshaft MN143620 Exhaust Camshaft MN137746 Intake Manifold MN156302 Exhaust Manifold MN135583 Down Pipe MR968097 Mid Pipe MN153192 Rear Section MD356000 MR oil filter MZ690116 oil filter (normal?) MN156784 O2 Housing MR299686 Metal Gasket to Turbine <-- parts to go with the O2 housing MD132933 4 x Washer MD062961 3 x Bolt MR224441 1 x Stud MD050073 1 x Nut MB914617 Front wheel hub assembly MN153285 front mount intercooler MN126772 Lower metal mounting bracket for the front intercooler grill MR370729 lower front caliper bolt MR407072 lower front caliper washer MS240121 Air box bracket bolts MS240142 overflow bolts MD748267 Evo 5 transfer case (inc helical LSD) MN155760 03-05 head gasket MR578634 02 lancer 0Z Front Oxygen Sensor MR507854 02 lancer 0Z Rear Oxygen Sensor MN143343 hose line for the blow off valve MR385780 heat shield bolts MF434103 MAF sensor nuts (4 pieces needed) MR554814 RH Lower Control Arm Asm. MR554813 LH Lower Control Arm Asm. MB914617 Front Wheel Bearing Asm. MR455707 lug nuts MB911495 wheel studs (frt or rear) MR571545 Fuel Pump Housing MF241251 Pressure Plate Bolts MR493288 Front Passenger side metal brake line ABS to Flexible line MR571544 fuel pump MN106046 gasket MB129895 in tank filter MR571592Air Intake Hose MN156291Air Cleaner Bracket MF661135 & MF661142 Band Clamps for air intake hose MD173306 Band Clamps for BOV MD151672 Mass Air Sensor Gasket MR498813 ’04 RS Transfer Case 3200A011 '05 RS/MR T-Case MN119784 (Manifold-Turbine) Stud MR224441 (Turbine-O2) Stud MB555284 Clutch Line Banjo bolt MF660063 Crush Washers for clutch line MS240077 Spark Plug Cover bolts MN156738 Oil return tube gasket (at oil pan) MR450703 O2 housing exhaust donut MR323654 Exhaust Manifold gasket (head to manifold) MD062961 O2 housing to Turbo housing bolts MN158795 Serpentine Belt – no A/C (RS model) MN153089 Wastegate Actuator MD743612 o-ring between transfer case and transmission small MD727944 O-ring netween transfer case and transmission large MR266706 Oil feed line MF660064 Crush washers (turbo side) MS650013 Banjo bolt (turbo side) MF650102 Banjo bolt (head side) MF660063 Crush washers (head side) MD329503Cam sensor housing cover gasket MR281085 Lower IC pipe to turbo gasket MD016483Valve keeper MD119127 EGR Valve gasket MN155455 Stock valve cover MB687014 Midpipe to Muffler gasket MR464630 Oil cooler MN143213 Stock boost solenoid MR475618 Brake Pad Shim set MR323654 Exhaust Manifold to turbo gasket 1540A019 Intake manifold gasket MD306079 Valve seal Intake MD307343 Valve Seal Exhaust MD613507 CHRA (Center section, turbo) MD604696 Fuel rail feed o-ring MB554317 Fuel rail return o-ring MD180361 Throttlebody gasket MN163343 Oil pan MR258477 Oil drain tube to turbo gasket MD132806 Cam cap dowel pin MN158072 PCV valve hose MD152772 PCV Valve MF244879 Turbo support bracket and bolts MD363254 Head-Coolant housing gasket All 4 mounts engine and transsee #514 MR491558 MR594455 MR554434 MR554653 Mount bolts see #504 MB569372 Trans. Drain plug MD701850 Trans. Fill plug MB001265 Transfer drain plug MD701850 Transfer fill plug MB569390 *Rear drain plug MB001261 *Rear fill plug * Crush washers included. |
To add, please include a picture (digicam, service manual screen shot, ect) to help aid me and others with getting you the part number for the part you need.
I don't have constant access to this board, but I can ensure you I can return your part number request ASAP if you send me an email (justdsm@hotmail) |
I need the part number and price if possible for the plastic covering of the steering column. The piece the guage pod is mounted to.
MR633538
You used my pic! :) |
yeah, you gave me what I wanted for the guage question. Thanks a bunch :)
what about the bolts that hold the cam gear cover, i don't have a a part no.
1 Attachment(s)
This is a cross post, but....
Can anyone help me with a Mistu part number. It is called the gear link bushing. It is not the cup that most people need to buy. It is the small little cup that goes on the end of the shifter balls. I buggered one up during a short shifter install. The answer is: MR232147 |
i need the following parts:
trunk liner (the full trunk thingy) the black plastic piece at the end of the trunk coin box and that it is for now {thumbup} |
the magnetic drain plugs from the evo.. i want to use the tranny ones on my RA.. is the oil one magnetic too?
-joe |
Nastea1, there are three bolts
MF247868 (1) MF140210 (3) MF140206 (6) that's what it lists in CAPS. Blonde Board, trunk room floor MR572609 Trim, Trunk room RR end (Grey) MR444269 Grey was the only colour available, and I couldn't find the coin box. Sillypuddy MD050316 Oil drain plug (this number is shared with the EVO and RA) MD569372 M/T plug (EVO #, this is not shared between the two, so I cannot vouch for whether or not it'll be proper fitment) |
This is great!! Good idea!!
Anyway, I need the part number for the little black 'screw type' fastners that hold the underbody plastic on. Sorry, no pics, but they are the plastic tabs that run along the bottom of the from bumper (underneath) and hold the black plastic upder peices in place. I'm missing a bunch of them. Also, Greme, the MD050316 part; is this the magnetic plug for oil, or just the regular drainplug? Thank You!!! |
I do believe you're talking about MB547806, "Clip, Engine Room Cover". It says there's 36 of them.
FYI, here are some popular part numbers for the evo
MZ690116 oil filter MR552951 air filter MR407376 Front pad kit (hardware sold separately) MR407391 rear pad kit " " MD979313 water pump MN158794 alternator belt MD186785 spark plug grommets MD340535 valve cover gasket MD152772 pcv valve MN132206 clutch disc MR980846 pressure plate MR145619 T/O bearing MD746617 clutch slave cylinder MR491945 clutch master cylinder MN149074 crankshaft pulley MR370723 front brake rotors MN153010 oxygen sennsor frt MR578532 rear oxygen sensor MD327107 cam position sensor MR578117 knock sensor MD363552 ignition coil MD343245 plug wires set MD374841 spark plugs MR455707 lug nuts MB911495 wheel studs (frt or rear) MR984375 timing belt adjuster MD369999 timing belt pulley |
Good guide, when I get back to work, I'll put up things like valve lifters and t-belts and gaskets and the like.
just trying to help
