| Dus10 |
Mar 12, 2005 06:32 PM |
Tried search couldn't find answer; Adjusting JDM MR headlights?
The USDM headlights on the MR have a little shaft that runs from the HID level motor to the High Beam adjuster cog; I guess when you raise and lower the HID's using the switch it raises and lowers both the low beam and the high beam so I imagine you can adjust the level of the HID with the adjuster on the High beam because they're connected.
Well... I installed the JDM MR headlights which doesn't have the little flex shaft running down to the high beam adjuster so I have no clue how to adjust the level of the HID's. I can adjust the high's and the fogs but haven't figured out how to adjust the HID. Anyone have a clue?
