Evo Do's and Don't's
I know like on a type r integra u can do aftermarket parts and lose power... is there any parts out there that may make the evo to lose power ? How about the parts that give u decent power gains not goin as far as upgraded turbo and so forth ? Any input will be appreciated
first tip, dont buy k&n typhoon intake
with the completion of mods... should come a tune... if not... the full potential of the mods will never be reached
What is wrong with the k&n typhoon intake I have it, and have no problems with it. It sounds great and has a substantial power gain.
a lot of people on this forum have had problems with it red..
what kind of problems have they experienced!!!!!!!
Alright when buying parts try to not mix macth the company's try to stay with one product so the parts can get the most power out of them and a proper tune will be reached
Intakes seem the most questionable mod. Do a K&N filter to get started. I can't recommend a flash enough and I'd start by looking at Works' flash. There are others.
Exhaust (after flash and with a flash also tuned for the exhaust upgrade) is biggest bang for the buck. If you can't do it all from the turbo, always start with the rearmost section (cat-back, for example). Exhaust and a flash are your best first bets - then there's suspension. A GOOD spring kit and rear sway is a start. Otherwise, to coilovers. Hope this helps. |
just make sure u get ur car tuned after doing mods.
it can't be said enough. TUNING, or else you've wasted your time modding.
| All times are GMT -7. The time now is 10:04 PM. |
