-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   reflashed ecu's for the evo 8? (https://www.evolutionm.net/forums/evo-general/130433-reflashed-ecus-evo-8-a.html)
deadbeatrec Mar 29, 2005 10:55 AM
i am very interested in reflashing my ecu for my 03 evo 8 and i was wondering which company has the best program? i was thinking either buschur, dynoflashe, or turbotrix. i need some input. i was also wondering if after i get my ecu flashed, is it safe to run a manual boost controler or do i need other upgrades like a 255 walbro fuel pump. so post some sugestions. thanks and i would like to here from david buschur about there ecu.
JeffR116 Mar 29, 2005 11:01 AM
Don't worry guys, I got this one...
https://www.evolutionm.net/forums/search.php
gsujeff55 Mar 29, 2005 11:01 AM
Call the above shops you listed and ask them what you need. This has been discussed ENDLESSLY on this forum, so try a search.
I will jab you a little advice though, go with the vishnu flash. And you won't need a fuel pump untill you mod your car some more. I would buy ATLEAST a turboback exhaust before i started messing with a flash and boost controller though.
HwangTKD Mar 29, 2005 11:16 AM
Dynoflash.........especially since you are from NY
DynoFlash Mar 29, 2005 11:20 AM
My new "Boost Controlled" Flash version works really well on Stock evos and you will never need a fuel pump. (Its just a saftey measure to ensure an ample suplly of fuel in the event of demanding driving operation). This flash is only $199 and holds a steady 19 - 20 psi. No MBC needed.
Also - i offer a vast library of customized tunes to match virtually any combination of parts. I have over 2,000 tuning combinations supported.
EVOTEXAS Mar 29, 2005 11:28 AM
Turbotrix All The Way!!!!
sleet Mar 29, 2005 04:08 PM
^^ I agree :)
Most-Wanted Mar 29, 2005 05:33 PM
I say go with DYNOFLASH:)
4TUN8 Mar 29, 2005 05:51 PM
Get a laptop and go nuts on your ECU like you know wtf you're doing!!
That'd be cool for like 10 seconds =p
deadbeatrec Mar 30, 2005 04:23 AM
wow u guys really got me in a rut. so its either dynoflash or turbotrix. i want around or close to 300 whp with a flash a turbo back exhaust an intake and a divertervalve. i have the other 3 on my car right now and she pulls really hard but now its time to but the boost and make sure it holds. so i need a fuel pump with the dynoflash huh? that sounds resonable but what kind of numbers do people run with the mods i have listed above? please help me out.
deadbeatrec Mar 30, 2005 04:24 AM
im sorry i read that wrong. i do not need a fuel pump with the dynoflash. but what else does the modified ecu do other then boost?
TurbotrixRacing Mar 30, 2005 05:03 AM
You dont need a fuel pump without cams, but why not do it. Its 100 dollars and its something your going to need eventually. If you get a flash without a pump then do mods a later date you would need another flash. IMHO .. do the pump...
Mark
Turbotrix
Dr. Fob Mar 30, 2005 05:08 AM
I have intake, full exhaust, MBC set at 20.5psi, and Dynoflash. Dynoed at 275hp and 306ft-lb.
Dynoflash all the way.
Iceman2011 Mar 30, 2005 06:31 AM
if you have the turboback the numbers seem kinda low. you should be more around 290whp easily with those mods
deadbeatrec Mar 30, 2005 06:49 AM
i currently have a full 3 inch buschur turbo back exhaust, an aem intake and a forge diverter valve. i fell like i can pull an easy 245whp with these mods. easyily. i was on the turbotrix website and i see no prices for flash? what do u guys charge for the flash and a fuel pump? i wanted to pull 300whp without doing any cams or internals or a turbo kit yet. so please fill me in because im new at this mitsubish stuff. my last car was a 2000 golf 1.8t which i had about 240whp and that thing pulled like a sob at around 60mph. it was crazy fast top end.so i am new at the jap stuff but i figured i would make this car faster than my golf so keep up the sugestions.
