-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   what's up with my car? (https://www.evolutionm.net/forums/evo-general/133821-whats-up-my-car.html)
Fred Apr 15, 2005 02:39 PM
Took my car in to fix a clunk noise plus a little bit of give to the left front wheel. It felt like the wheels was a little louse if that makes any sense. Anyway, I was told that my wheel bearing needed to be replaced, they did that under warranty. That did not fix the problem; at that point, they ordered a new strut to the left. Got the work done today, the noise and the give are gone. However, my car now vibrates during braking from around 75mph. I also think that car is puling a little to the right. Lastly, my steering wheel looks off center.
Do I need to get the car aliened after the strut work? Also, what’s up with the vibration during braking? I would appreciate some feedback on this as I am taking the care back tomorrow and want to be prepared to deal with their crap.
Thanks,
twinevo Apr 15, 2005 02:49 PM
the vibration during braking sounds like warped rotors
stormhalter Apr 15, 2005 03:08 PM
Was the vibration present before the installation of the new strut? If not, you may want to take it back and explain what happened after they worked on it and released the vehicle to you.
If it was present before, then I would say warped rotor. I have seen similar problems from uneven brake pads wear.
heSOshAdy Apr 15, 2005 03:13 PM
how much does it cost to replace rotors or get them fixed? thanks
UT_Evo Apr 15, 2005 03:16 PM
If it's not warped really really bad, they can just turn the rotor, it doesn't cost too much. It's not a hard task.
stormhalter Apr 15, 2005 03:27 PM
Yeah, take your rotor to any advanced auto parts or pep boys, and they can turn it for about $15 per rotor. That's how much it is down here.
Shady: OEM replacement rotors are pricey. Not sure on the exact price. Probably better off going with Brembo, Wilwood or Baer for new rotors. MM charges an assload.
negativeB Apr 15, 2005 03:35 PM
Thanks,
no. i think terrestrial work will be fine.
Fred Apr 15, 2005 09:11 PM
no, the vibration was not presente when I dropped the car off. I am really not sure what is going on
kataklyzm Apr 15, 2005 09:24 PM
if they torqued the wheels too tight it can warp the rotor
Fred Apr 16, 2005 07:17 AM
thanks,
i am going to take a look at what they torqued my left wheel.
