Revlimiter 05's?
I have an 05 and i can rev in gear up to 6-7k..........is there something wrong with my car is it only on MR's that have the rev limiter. Plus i know alot of you are going to probably flame but i also hit 160 in it( nobody was on the road 3am stright away fro about 10 miles so id ecided to see what the car had) and my buddy in his mr said 05's and and his mr cut off at 140? Should i talk to the dealer about the rev limiter or just be happy i dont have one.
mine does not hit rev limiter until ~7600 ish.
is it an 05?
Originally Posted by AutobonEvo
is it an 05?
true well iv met some people with 05 that cant rev above 5k.
All 05 have a rev limter in neutral, not while driving in a gear. The rev limiter is there to help prevent abuse of the drive train.
As far as top speed, I dont know why the MR would be limited at 140 and you aren't until 160. Maybe tire speed rating differences? I thought all the evos had the same exact tires though. You got me |
Yeah same here. In gear and in neutral i can rev to 7k. top speed yeah its weird the Mr just cut's out at 140 and mine kept going who knows my old wrx dipped way past 140 and buddies didnt.
Originally Posted by bluetouring350
that is not true. mine does not as i previously stated. in neutral i can rev it to the rev-limiter. i have not attempted a 5000rpm clutch drop yet so i do not know of this.
As for going 160, regular factory speedometers are not accurate at such high speeds, so it's likely you weren't actually going that fast. |
It only does the 5k 2-step limiter when the clutch is depressed and the car is not in motion.
well 7.6k i was just sayin 7k just to be general. Yeah 7.6k it will hit rev limiter.
well then that explains it. the clutch is not depressed while im in neutral, thus no 5k limit.
| All times are GMT -7. The time now is 10:05 AM. |
