-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   272's installed boost went down (https://www.evolutionm.net/forums/evo-general/142373-272s-installed-boost-went-down.html)
ThEHiTMaN Jun 3, 2005 09:01 PM
I have noticed that my boost has gone down since I installed my 272's is this correct? I was peaking in the high 23's now in the mid 22's also was holding 20ish to redline now i am only holding 18-19.... Should I crank it up a notch?
rlazer5000 Jun 3, 2005 10:33 PM
Boost is gonna go down because the higher lift intake cam decreases vacuum pressure. I would recommend getting a tune before turning up the boost.
Iceman2011 Jun 4, 2005 05:59 AM
^ true
rraulston Jun 4, 2005 06:10 AM
the longer you keep the valves open, the more boost that goes into the cylinders, the less pressure is measured in the intake manifold. Thus a lower reading. Make sence?? Cranking it up with out logging AFR and knock could be risky. I would advise you tune it.
nolimits1320 Jun 4, 2005 08:38 AM
264's dropped my stock boost to 13psi.
Evo348 Jun 4, 2005 10:43 AM
would reflashing the ECU fix the idle that the 272s give the car? Or it wont help?
rlazer5000 Jun 4, 2005 10:49 AM
A reflash will help, and also the use of adjustable cam gears.......both will give u a stock like idle.
ThEHiTMaN Jun 4, 2005 11:42 AM
I might just invest in a Wideband and tune it myself.
