For those of you hitting low 12’s
Did you run that with the stock clutch? With race gas or pump? Last weekend I went to the track with the Evo for the first time and no matter what I did, I was only able to pull a best of 14.07@101.93. This was done on stock clutch with 21,500 miles on 92 oct + a 32 oz can of Torco Fuel accelerator additive. I don’t really feel the clutch slipping but it seems it’s not able to put down the power to the wheels. I’m going to put in an after market clutch and go at it again next month hopefully my time will improve. Here are my mods:
BR 660 injectors 255 fuel pump 246i/272e cams BR MBC@22psi BR upper intercooler pipe Custom street tune by Dynoflash HKS RS intake BR Turbo back with highflow cat |
I think you need a little more practice, but it's also possible that something is wrong with your car, possibly a boost leak, your MPH are way to low for your mods. Most of the time I like to put most of the blame on the driver, but in your case there probably is something wrong with your EVO, your way down on power, Cams, TBE, and Flash, and only trapping 101mph, something is wrong.
yah, i ran 117mph on the stock clutch with very similar mods to yours....although, its was on vp 110.
BR 660 injectors 255 fuel pump 246i/272e cams BR MBC@22psi BR upper intercooler pipe Custom street tune by Dynoflash HKS RS intake BR Turbo back with highflow cat 12.6@107 - cat-back/safc/mbc - stock clutch on 93oct 12.2@111 - cat-back/safc/mbc - stock clutch on 93/104 oct mix The stock clutch doesn't stop Evos from going low 12s, on your mods. It doesn't stop us from 13 flat in stock form. I think the mileage on your clutch may be causing issues even if you don't feel it slipping. That, or you're not launching and have 2.5 60's. |
12.21 @ 115 with a beat up stock clutch, restrictor pill still in,93 & 104 octane mix.
Well...my R/t = .125 and 60' = 2.20 which is not the greatest but I would think even at that 2.20, I should still see 13's. I was launching at 5000-5500 rmp slipping the clutch of the line, lifting foot of gas pedal b/w shifts (maybe this is part of the problem). Car just seems like it didn't have enough juice down lown to get me a good 60'. I'll have to try a bit of race gas next time.
hawjdude-yeah that was at rockfalls:) |
11.9 116mph with act clutch and hand full of mods
hawjdude-yeah that was at rockfalls:) Don't add race gas just to mask the problem. You need to find out why your car is only hitting 14s and only 101mph the way it is now. Once you've either figured out the problem or improved enough to know that there is no problem, THEN you can add race gas or other mods without worry. If you change any variable next time you go, then you'll never know what really caused the improvement (if any). |
Originally Posted by fromWRXtoEVO
Tell us what year of EVO you have and what your 60' times are. You should be at least below 13.5s and at least trapping 104mph.
with about those same exact mods and 6K above sea lvl i wanr a 13 flat. i was on stock clutch and 91 oct. doing low 1.8 60 foots
BR 660 injectors 255 fuel pump 246i/272e cams BR MBC@22psi BR upper intercooler pipe Custom street tune by Dynoflash HKS RS intake BR Turbo back with highflow cat HKS Racing Suction Intake GReddy Racing Titanium Exhaust HKS Super Sequential Blow-Off Valve Type 2 Helix Downpipe Helix High Flow Cat HKS Type R Intercooler HKS Circle Earth System Greddy Oil Catch Can Apex Boost Controller(@1.55bar) |
[QUOTE=Carbonics]. But my best trap is only 102.96 and that was with the clutch slipping 3-5th.
why in d h3ll are you shifting into 5th gear , or did you mean 4th gear ? |
