can't get my pocketlogger to work
I just purchased a palm m100 w/ a pocketlogger cable and software from another Evom member. The problem I'm having is that I can't get the pocketlogger program to "register" at all with the code I was given. Does anyone know if the name that was used to purchase the software has to be the same as the one on the plam pilot?
Or even better if anyone has a name & reg code they can email me at alwaysinboost_at_msn.com it would be great. Also I tried two other "free" logging software types but I can't seem to get them to connect with my car. my friend told me that pocketlogger places a chip or something in the OBD2 cable so it will only work with their software, is that true? |
from what I heard the code they issue to register the program can only be used with the palm unit that the original owner of the pocketlogger used. Otherwise you have to pay a $25 transfer fee to use it with a different palm unit, check pocketlogger's website for more details.
I think your right. I have all the original software and the palm that was used to register everything but the guy I purchased the stuff from only gave me the reg code, no name to go with it. I've already sent him 2 emails and a PM :crap: but he is extreamly hard to get a hold of!
the registration code and hotsync used name are what I need. the guy I purchased my logger from only gave me the reg code. :rolleyes:
http://www.pocketlogger.com/maincont...t_hotsync.html Any help would be appreicated{thumbup} |
unfortunately, there's not much you can do... if you can get the user/owner name he used then download a program called "HackMe." You can use it to alter the owner/user name for each individual program on the palm. You should set the owner of the PocketLogger software to his name and then register the software.
i have 2 sets of pocketlogger Username/Reg codes but i'm pretty sure that the codes are dependent on the serial number of the cable. you can PM me and i'll try to help as much as i can. good luck (definitely try the HackMe thing) |
did you re-name the palm? because if you didn't it shouldnt have "unregistered"
Sent you a PM. ;) |
replied...i hope my info helps.
| All times are GMT -7. The time now is 06:01 PM. |
