-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   won't start (https://www.evolutionm.net/forums/evo-general/197059-wont-start.html)
d evo 1 Apr 22, 2006 06:53 PM
won't start
removed battery and left it out for a couple hours and after putting it back in car won't start. it cranks but won't fire. anybody have any ideas? thanks
CtSilver03Evo Apr 22, 2006 06:55 PM
You check all the plug wires, they connected to the coilpacks? Also, connecter still on starter? Do you have any modifications you've made to the electrical system? Check fuses too.
d evo 1 Apr 22, 2006 06:58 PM
it cranks but does'nt fire. battery was only removed to look at and possibly install in trunk.
CtSilver03Evo Apr 22, 2006 07:00 PM
check the coilpacks.. if it cranking, there might be something prohibiting the car from sparking.
Compjoc Apr 22, 2006 07:05 PM
Check the fuses.
d evo 1 Apr 22, 2006 07:19 PM
Originally Posted by Compjoc
Check the fuses.
checked fuses. nothing is blowen. nothing was done under the hood. only removed battery to look at how much room there is without it.
mump Apr 22, 2006 07:25 PM
did you check the big square fuses under the hood?
fromWRXtoEVO Apr 22, 2006 07:29 PM
Do you have an alarm inmobilizer?, sometimes they wouldn't reset and they operate in silent mode. Somtimes is caused by somethingas samll as living a door not properly close.
Reset the battery again. lso make sure the positive cables are well secure, the positive connector on the battery has some big square fuse with electronic component, just make sure that is also plugged.
Carlos
