-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Help. oxygen sensor won't come off. (https://www.evolutionm.net/forums/evo-general/206815-help-oxygen-sensor-wont-come-off.html)
badbrain Jun 16, 2006 02:57 PM
Is it safe to use PB nut loosener on the oxygen sensor? Or can that damage it? I can't unscrew the thing.
inco9nito99 Jun 16, 2006 03:06 PM
Use PB around the contact area, use 1 open ended wrench and one closed to get more of a leverage.
badbrain Jun 16, 2006 03:11 PM
I'll try that, thanks.
kreionic Jun 16, 2006 04:38 PM
I had the same problem it was a betch to get it will come eventually
PANGES Jun 16, 2006 05:31 PM
I had a problem with that when I was doing my testpipe, I used a screw driver to take off those clips so I get more length in the wire first, then I pull the cat out from the passenger side of the car till I have enough room to actually stand the cat upwards. Then I put an open end wrench on the o2 sensor, and used my BFH (Big F*ckin Hammer) and hammered on the wrench and the o2 sensor slowly unscrewed out. Worked like a charm :) Remember, if brute force does'nt work... then you're not using enough of it. {thumbup}
4TUN8 Jun 16, 2006 05:33 PM
Deadblow hammer.
mitsuorder Jun 16, 2006 05:35 PM
let the car run for a bit, not too long, give it a try, don't burn yourself :thumbup:
PANGES Jun 16, 2006 05:38 PM
wont the heat make it worse because the metal will expand? Mine was pretty warm when I did it though...
EvoRicer Jun 16, 2006 05:46 PM
WD 40, let it sit for a few mins, use some muscle and you have a loose O2 sensor...
VtecGSR952000 Jun 16, 2006 06:35 PM
can you fit an 02 sensor socket on it?
PANGES Jun 16, 2006 06:48 PM
they make o2 sensor sockets?
VtecGSR952000 Jun 16, 2006 06:54 PM
Ya, they are great! have a small groove cut up one side to allow the wiring through and the contact all sides of the sensor. Very nice! I think I picked one up at the zone for 5 bucks.....well worth it!
EvoRicer Jun 16, 2006 06:55 PM
It's impossible for a socket to take off an O2 sensor...even if they made a Socket for an O2 sensor...there's no way to get the socket on there unless you cut your wires.
VtecGSR952000 Jun 16, 2006 06:58 PM
OK.....if it is impossible to use it then why would they manufacture it? :confused: I have used it numerous times with no problems. If you dont have one and havent used it you cant really make a good judgement about it can you? {thumbup}
BADEVO Jun 16, 2006 07:00 PM
Stop making assumptions if you have no clue.
http://images.google.com/imgres?imgu...lr%3D%26sa%3DN
http://fordfuelinjection.com/images/tools10.gif
