-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Jerking clutch/drivetrain on low rpm's, need some feedback. (https://www.evolutionm.net/forums/evo-general/211278-jerking-clutch-drivetrain-low-rpms-need-some-feedback.html)
alloyic_rs Jul 12, 2006 07:24 PM
Ok, my evo rs is stock except a catback and 22,000 miles. Whenever I startup the car in the morning I let it Idle for about a minute and then I take off to work. I do, however, have a problem. When I start moving in first gear at about 2,000 rpm's or below I get this insane clutch or drivetrain jerking, and I can hear it go all the way to the back to the rear diff. To stop this weird vibration i just step on the clutch. This happens all the time when my car is cold but even sometimes when my car is warmed up. It doesnt happen when I rev higher, like from 3,000 rpms.
So has anyone else experienced this in their evo? I have a stock clutch btw.
Should I just rev higher when i move in first gear and forget about this jerking motion? Should I have the dealer check it out? Feedback is appreciated.
alloyic_rs Jul 12, 2006 07:37 PM
bump
nothere Jul 12, 2006 07:42 PM
sounds like you're a little lean. yeah, let the dealer fix it. I am surprised you don't have a cel.
alloyic_rs Jul 12, 2006 07:44 PM
lean? you think that has something to do with how the drivetrain works when its cold?
nothere Jul 12, 2006 07:51 PM
no, I may not have interpreted what you said correctly, but a lean condition in the start off load cells will make your car jerky. The quick fix is to engage the clutch and get it more gas.
sort of like starting out and the engine just dies off and then bounces back, dies off and, again and again till you creep out of those cells.
you are correct I didn't read the post right, but without any real mods, why wouldn't you take the car back?
alloyic_rs Jul 12, 2006 07:55 PM
I guess ill let the dealer check it out, but i was wondering if this is a common issue among other evo owners.
Cabo Jul 12, 2006 07:58 PM
This sounds like a somewhat common "clutch shudder" issue that the EVO VIII has. Since you are in NC, you will probably notice it a lot on cool, humid mornings. Mine had the same problem. It goes away after everything gets warmed up.
The only solution I found was to back off and try again (revving higher helped).
For the record, I had the exact same problem on my 3G Eclipse, which I believe may share some parts with the EVO.
Cabo
alloyic_rs Jul 12, 2006 08:00 PM
ahh, well that makes sense, the cold humid mornings, would a stainless steel clutch line help reduce this?
Cabo Jul 12, 2006 08:09 PM
I don't have the knowledge to say for sure, but if it's not too expensive it might be worth a shot (and it will help engagement anyway). If that doesn't work though, the only other option I know of would be to go with an aftermarket clutch (and there's no guarantees there, so do some research before you make that investment).
Cabo
Dr. SS Jul 12, 2006 08:16 PM
give it more gas when its cold.
Fourgig Jul 12, 2006 11:09 PM
Is the jerking almost like wheel hopping? Cause I get that on my MR as well. I live in Northern California so it can't be because of the cold.
alloyic_rs Jul 12, 2006 11:25 PM
no my wheels dont hop, but my whole drivetrain starts to bounce, as if the clutch is gripping and slipping really fast
GinuwineEvo8 Jul 12, 2006 11:50 PM
Adjust the clutch ... or learn how to modulate and slip the clutch smoother ..
LOL I cant believe homeboy said its because of a lean condition .. AT IDLE ... LOL WTF?
viciousv322 Jul 13, 2006 12:19 AM
could it be the restrictor in the clutch line that doesn't allow the clutch to engage completely? Or at least not as predictable...
AirNKAir5 Jul 13, 2006 12:37 PM
i have the same problems and after switching out the clutch, it still does it. After the car is wamred up everthing is fine though
