-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   won't boost to 1.4 bar at 3 4 5 gear (https://www.evolutionm.net/forums/evo-general/226918-wont-boost-1-4-bar-3-4-5-gear.html)
oldscholevo Oct 3, 2006 06:40 AM
ok these few days I was pulling the car hard and notice that at wot at 3 4 5 gear, the car won't boost up to 1.4 bar. but when in 6 gear the boost will go up to 1.4 druning wot. at 3 4 5 gear the boost stays at 1.1 bar. :confused: whats going on. did some search, can't find anything close to my problem. please help. check the car everything is good. should i reset the ecu??
3SgteGuru Oct 3, 2006 07:57 AM
The Boost is supposed to Taper, somayber in the Lower gears your gaining rpm too quick and cant built boost fast enough to reach the Peak boost. Possibly you have a Boost leak. I reach Peak Boost if I pull at like 2700 rpms in 2 at 3000rpms in 3 and 4 and 5 6 pretty much any time i WOT it if i am Above 2500 rpms, car is stock The peak boost of all gears ist at 3500 rpms, but the Rpms i listed are the highest rpms i can start the pull at to reach the peak boost by 3500. My freinds Electric blue evo, He has a TBE and IC piping and Intake w/ a tune from AMS and a Profec b-spec II tuned to 23 psi, pretty much anytime you give it wot it shoots up to 1.4 to 1.6 bar. So its realy different from my Stocker, I did a Second gear Pull with him and he just Took off Like a Rocket.
oldscholevo Oct 3, 2006 08:05 AM
ok. because if i was on high way the boost will reach 1.4 at 6 gear no matter what rpm range and stays there, but when i pull at 3 4 5 gear the boost will go to 1.4 and drop right down to 1.1, without going to redline.
oldscholevo Oct 3, 2006 08:06 AM
if i have a leak 6 gear pull won't stay at 1.4.
3SgteGuru Oct 3, 2006 08:33 AM
IF you Peak then Drop That normal, part of the taper. You do not have a boost leak. Your car is fine.
FYI boost leaks don't change your peak boost level, but change the rate at which you build boost.
oldscholevo Oct 3, 2006 08:58 AM
ok thanks for the help. I will double check the car, just to make sure everything is good. {thumbup}
3SgteGuru Oct 3, 2006 10:14 AM
Good luck with your car man, If you going under the hood, just make sure your clamps are tight, you know the Ic pipe problem, use a 10mm socket.
oldscholevo Oct 3, 2006 11:02 AM
thanks!
AhmadHasib Feb 4, 2007 12:45 PM
im just writing so i can find this thread in the future
armympjch Feb 4, 2007 12:53 PM
be careful when racing with the MR. the 4th gear is weak and can brake if your shift hard at high speeds. i guess that it has started happening alot with the MRs, the 4th and 6th gears are weak. i broke mine and now im getting a custom built 5 speed to put into my MR from ShepTrans.com........ just a heads up.
Warrtalon Feb 4, 2007 12:55 PM
It doesn't typically break from shifting hard. It breaks from the teeth weakening over time due to excessive heat and the breakdown of the fluid. I had over 250 drag runs with 200+ of them including 3-4 powershifts (as hard as you can shift it), but I didn't lose 4th until I was road racing and passing a car in 4th. 4-5-6 are all small and weak with tiny teeth.
I also moved to a custom 5spd from Shep.
Kdash106 Feb 5, 2007 12:40 AM
i was wondering if is normal to hit 1.3 at 1st gear?? i think my car never peaked at 1.5 before. is that normal?
Evo IX MR Feb 5, 2007 01:23 AM
It sounds normal. I hit 1.4 down to about 1.2 at redline. No aftermarket boost controller.
3SgteGuru Feb 5, 2007 05:27 AM
^^ is the only one i can Find who has blown apart the MR Tranny. And I drive like a panzy, so i don't have to worry. Go to you tube and find one of his Vids, yeah he drives to win.
