-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   All ACD lights on, car feels like it's pulling timing... (https://www.evolutionm.net/forums/evo-general/228295-all-acd-lights-car-feels-like-its-pulling-timing.html)
bboypuertoroc Oct 10, 2006 03:28 AM
Yesterday while driving, all 3 ACD lights came on. Also, during the drive back once that happened, every ~20 seconds it felt like my car would pull timing or hitting fuel cut (like it did before my flash running higher than stock boost with an intake). The car is going in to Mitsu on Wed, just trying to get any info I can here beforehand to make sure they don't try and jerk me. Thanks for any help.
M00kiE Oct 10, 2006 04:04 AM
i forget what that means but im sure it tells you in the maunal...
Greg K Oct 10, 2006 04:16 AM
3 lights = ACD fault. Could be anything from electrical, to hydraulic, to mechanical. Good luck and keep us posted.
chaz517 Oct 10, 2006 06:18 AM
hey that happened to me once and i realized the negative part that goes onto the battery i didnt tighetn down all the way and it popped on and off, so i disconnected it and let it sit a few minutes after pumpin the brakes and it was fine afte rthat, good lck
DRFTKNGG Oct 10, 2006 06:22 AM
You need to bring it to the dealer. 3 lights are the fault code for the acd. Needs to checked out.
DRFTKNGG Oct 10, 2006 06:24 AM
Try resetting the batt. Then turn the key to the on position without starting. Floor the gas pedal a few times. You should here the ACD pump. This is how we bleed the ACD. Sometime this works.
