-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Double boost gauge's (https://www.evolutionm.net/forums/evo-general/229314-double-boost-gauges.html)
ak47po Oct 15, 2006 05:29 AM
I have the stock gauge cluster in my MR,i want to put a Defi Blue Racer Boost Gauge on the steering colum with a Autometer EVO Steering Column Gauge Pod .
The thing i would like to know is, i want like to keep the stock oil temp and voltage gauge's for now.Can i leave the stock boost gauge connected and still install the Delfi without problem's or do i have to disconnect the stock gauge.I really don't like the location of the stock boost gauge and i don't want to move the whole gauge cluster just for the boost gauge.The answer is probably obvious,but i would like to hear it from someone that know's more about this then i do.Any comment's would be great,thank's. :thumbup:
Rob W. Oct 15, 2006 05:34 AM
Just T off the line and you should be fine with two gauges. You could technically hook up as many as you want.
ak47po Oct 15, 2006 05:36 AM
That's one for yes.Thank's Rob W.
ak47po Oct 15, 2006 06:26 AM
Anyone else.
Evo8zip Oct 15, 2006 07:21 AM
shouldnt be a problem, just a t fitting like already stated....the theory on hookin up as many as you want may be off though....more tapping and extra vacuum lines probably gonna = less accurate gauges....but 2 should be ok
ak47po Oct 15, 2006 07:22 AM
Thank's
ak47po Oct 15, 2006 09:57 AM
Bump.
KOEvo Oct 15, 2006 10:06 AM
Do it, you won't have a problem; just T off the already existing line like Rob said.
It will be nice to check the Defi to your stock gauge for accuracy also.
ak47po Oct 15, 2006 10:08 AM
Sound's like it's a go thank's guy's.
chaotichoax Oct 15, 2006 01:18 PM
yeah having two believe it or not is a beautiful thing
I have an autometer boost gauge and the stock mr gauges...my autometer line got kinked when I adjusted my steerting column so it wouldn't go past 15 psi
but I checked my stock gauge it went straight to 1.5 bar so I knew something was off...then I traced the autometer line and bammm it was kinked
mine is just tee'd off the stock line...it's a great concept since boost leaks do occur
ak47po Oct 15, 2006 03:23 PM
Ttt.
fromWRXtoEVO Oct 15, 2006 03:28 PM
You can connect as many boost gauges as you want. I have the stock plus the Defi BF imperial series but as far is having gauges there is no limits.
Just add another T fitting for the Defi gauge. You can connect the defi close to existing MR stock boost gauge.
Carlos
ernald711 Oct 15, 2006 03:31 PM
Carlos
yes
DruMMinStUd06 Oct 15, 2006 03:47 PM
if you havent already found your answer...yes, you can put more then one gauge. i have the MR gauge and a defi bf hooked up.
saiyanzzrage Oct 15, 2006 03:50 PM
why the hell are you bumping an already useless thread?
