Warm up / Warm down routine?
Does anyone here have a warm up routine for their car as well as a warm down routine that they parctice evryday?
I usually wait for the revs to drop a bit in the mornign before heading to work and, depending on how I drive, I let the engine idle for about a minute before shutting off. |
In the morning, I let it run for a few mins depending on the temp outside and warm down I have a turbo timer...
Argh..... turbo timer....... need to get that!
30 seconds to warm up...1 minute to cool down.
im pretty weird on start up...well not really weird but i usually wait until the temp needle is halfway up.
cool down i wait a few seconds. most of the time im off boost. especially when looking for a parking space. no need to sit for a minute. |
Originally Posted by Drill_Sergeant
(Post 3848040)
cool down i wait a few seconds. most of the time im off boost. especially when looking for a parking space. no need to sit for a minute. It's somewhere in the owners manual I believe.... |
cool down time depends on how you drove the car for the last few minutes before shutting off the engine. If you prety much stayed out of boost then none is needed, but if u boosted like a maniac then you probably need to cool for 5 mins or so.
I let it sit until my revs drop a little then I stay off boost as much as possible until the car is warmed up
my tt is set for 50 seconds to cool down |
It says it in the manual guys. Don't drive until the temp needle moves a bit, I wait until it goes above the cold line. And like other said, if off boost I usually sit for a minute or so, but if boosting alot right before then I let it sit for like 5 or so cycles of the fan....a few minutes. But usually I am covering up all the seats and stuff to protect them anyway from the sun and I just turn the car off after.
I don't let the car warm up for more than ~20 seconds before I take off. I drive gently for about the first 5 minutes. And I don't cool off too long either if I drive normally, maybe ~10 secs. You know, the car idling is rougher for your engine than if you drive it easy and let the fluids circulate. And on the cool off, you're only affecting the turbo and the oil circulation, which isn't a huge deal since we have water cooled turbos... and it seems like half the people upgrade turbos before the stocker ever comes close to seizing.
i wait until my oil press hits about 50psi (1/4 temp gauge) and i let the turbo timer run for about 30sec for easy driving, 2mins for "spirited" runs.
I let the needle rise a little then im off. keep revs below 4grand. Cool off. I do have a turbo timer but dont use it. Reason? I dont really need it and I never run the car hard then shut it off. If I run hard I take it easy for a mile or 2 before getting home.
The owners manual is very specific regarding warm up...
"The engine is warmed up enough for driving when the coolant temperature gauge indicator starts to move." |
warmup usually at least until the needel starts to move, and then I drive it slowly until the rest of the car warms up ~5-10 minutes.
cooldown, if no boost for the last 5-10 minutes then I shut it off, if boosted then at least 5min. also after the longer trip I leave it for like 2-3 min. as well. During autoX events I set my timer to max which is 10min, but if it is really hot I might give some more |
well my car is heavily modded and doesnot like cold or cold starts so i usally let it set for a minute or two
and then for cool down i have a greddy turbo timer |
