Since I'm the only guy running a Blouch Dominator 3.5 Turbo.....
Guess I should post up some dyno results huh!?!?!
This mustang is calibrated to factory specs btw. http://img1.putfile.com/thumb/3/8022124436.jpg 420AWHP/373ft-lbs |
so what is a dominator turbo? what gas is this?
What happened to the 20g?
Dominator Turbo is a line of Turbo's from Blouch Turbo, you can check out the different Dominator series at www.blouchturbo.com
this was 93 octane with methanol |
Originally Posted by Cali2MDevo8
(Post 4118771)
I obliterated it. Read more about that at https://www.evolutionm.net/forums/sh...d.php?t=256167 |
what are your other mods?
so give us some info. what does this turbo compare to and what makes it good or better then its competitor sized turbo????
Compares to a....I have no clue, it's something no one has done hah.
My other mods oh god, I need to keep them written down for occasions like this. 272/272 cams ebay intercooler TurboTrix manifold MBC SMC Alky Supporting mods Blouch Dominator 3.5 turbo. Stock ecu, stock head, stock intake mani, etc etc. |
Are you still running a 2.0L?
From the plot it looks like that turbo is really laggy. How does it feel on the street?
Mitch Mckee |
Still on the stock bottom end, and the car does feel somewhat laggy like a large turbo car does.
have you been to the track w/ this turbo yet???
How much boost you running?
Havent been to the track yet.
Running 30psi on my gauge and 27.5 on CBRD Speed Factory's MAP sensor. |
Sorry but isn't that pretty low for a 52 lb per minute turbo? What did chad make on his 35R on pump gas?
Scorke |
| All times are GMT -7. The time now is 01:43 PM. |
