| mudduck |
May 25, 2007 08:59 PM |
Need some help with warm start issue after cams and 750's in...
Guys, I could really use some help with my car's new warm start trouble. Seems to start better when car's cold, but when it's warm, it starts "technically", but for the first few seconds the engine is either being choked (not enough gas getting in) or maybe flooded?
Upon starting, the engine always turns right away, but then seems to struggle to come to life - rpm's are like around 200-400 initially, then seconds later the engine comes to life and idles perfectly. No idle problems or stalling whatsoever once car is started. Goes WOT perfectly as well as drives smooth around town.
Last thing, the problem began after I had cams and 750cc injectors installed, followed by a custom dyno tune...
Any thoughts? Do you think it's the injectors are not properly scaled, too rich or lean at idle, or need plugs changed (have never been changed)? Car has 14k miles on it and mods are below in sig... Thanks, guys {thumbup}
