Socket stuck on spark plug and can't back out
My 13/16 socket is on top of the spark plug in the plug well but I can't get it out and my extension won't plug into it. I tried moving the socket around and its stuck on the plug pretty tight. Any ideas?
what do you mean your extension wont plug into it? you must have used a pretty thick socket im assuming?
basicaly i tried to loosen the spark plug with the extension but my extension won't plug into the socket thats stuck on the plug.
since the spark plug is all the way in the socket its probably loose enough to use a magnet. try it
stick a flathead into the square hole & loosen until u can fit the extension back in. u may have overtightened the plug. i hope the motor is cold while ur working on it...
Take a pic. It sounds to me like the tip of the spark plug is in the hole preventing you from inserting the extension? Need a picture. If so, vice grip the socket and tap it gently side to side with a rubber mallet.
that is exactly whats happening, I tried some vicegrips but they were too large. I probably need to get a really small one to fit through the plug well.
Originally Posted by Skywarp
(Post 5186381)
oh please post pictures!
I dont have a camera at the moment but the guy above explained it perfectly.
Originally Posted by omniprobe
(Post 5186389)
Maybe you could try to insert a screw driver with the tip heated and bent to an "L" shape and try to insert it in to the square drive hole between the socket and the plug. Try to pull it up. Well, if all else fails and your socket is meaty enough.......1) make sure all the plugs are in (for shavings) 2) get your drill out and make a hole off to the side of the square drive . 3) tap it and thread a long enough screw into it 4) pull out your trusty ol' clutch changin',axle pullin', slide hammer out and yank her out.:lol: Good luck bro. |
needle nose pliers worked. This time around I didn't drop the socket all the way in but just enough to start turning the spark plugs loose. The install was the same I just used the extension with the socket then drop it down then tighten it with my hands until I couldn't anymore.
I suggest buying a real spark plug socket. :rolleyes:
Originally Posted by barneyb
(Post 5188530)
:lol: |
Originally Posted by 90GSX-03EVO
(Post 5188681)
I can't believe that people don't use spark plug sockets for changing their spark plugs.
:lol: |
| All times are GMT -7. The time now is 04:15 PM. |
