where 2start? couple Q's
hey guys,
as some of u saw, got in a fender bender, got my $,now its time 4 some new parts{thumbup} currently 05' stock VIII daily driver goal is decent gaines on stock turbo w/out killing wallet :rolleyes: 1st mods im looking at are... AMS/ETS fmic, AMS tbe, K&N drop in(will that work?) Heres my questions -Do I need new uip/lip w/fmic or will it be direct replacement? -Are there any other required mods/purchases to make these 1st upgrades happen? -Any other suggested upgrades to do @ same time(keeping in mind im not rich:updown: ) -is this an install I should tackle myself?(mech inclined/just no experience installing items listed) thanks guys |
You should be able to easily install the intercooler yourself.
Get a FMIC + LICP combo and pick up some T-bolt clamps while your at it. If you want a UICP, your going to need to buy a mini battery for the piping to fit. This also cleans up the bay a little and saves you some weight. Drop in intake I would hope you would be able to do yourself :lol: I have the WORKS drop in and like it a lot. But K&N will work well also. Exhaust you might want a shop to do for you depending on your available tools and knowledge. Also your going to want a O2 fouler to get rid of that annoying CEL. Definitely going to want to pick up a Walbro 255 fuel pump and if your budget supports it, get some cams. Boost gauge, AFR gauge, and boost controller and 02 housing. Other than that, make sure you get a good tune after everythings in and you are set! |
I dont know if I would make my first mod my intercooler. The stock intercooler is pretty good for a while defintly not a first mod. You should be looking at opening up breathing, TBE, or Intake Pipe and filter you will see better gains.
If you have 8 you want to replace your fuel pump for sure, but a nine has a slightly better pump and you can live with it a little longer, but I wouldnt go increasing your boost with out replacing it, they are pretty inexpensive on the forums, like 40 for a used and I think 80 for a new..... worth the investment.... My mod path suggestions First: TBE Intake pipe and filter Walbro 255 optional tune - you will see better results with a tune Second: Cams IC pipes/ mini-battery (The mini-bat makes the IC pipe routing better and cleans up the engine bay) you dont nessary need cam gears, majority of the evos I see running around have their $250 adjustible cam gears set at 0 0, waste! MUST HAVE TUNE b/c of cams Third: Boost control bigger injectors Inter cooler maybe a meth kit MUST HAVE TUNE Fifth: turbo kit defintly a meth kit (aquamist) MUST HAVE TUNE At some point throw some gauges etc in there, but im listing stricktly power adding parts I have seen several people follow this path, its relativly easy on your walet and you will see/feel power gains with every step |
aside from the great responses read the link in my signature...and search
closed... |
| All times are GMT -7. The time now is 04:05 PM. |
