Looking for code info P0443 (HELP!!) PLease
I know what the code is but what causes it and such, I just installed cams in my car and had the top end built. Plus a new clutch. ohh and a walbro 255 pump might that have something to do with it?? What might be causing this code and whats the best way to fix it ,thanks very much, KEVIN
po443 code, fix
you probably know this, its a purge valve code, and most likely the intake manifold vacuum has decreased. you may want to start by replacing the purge valve, and see what that does.
Thanks, I think I am going to start to make sure every thing is clear and easy running back there maybe I bent a line over or such, and that all is put back right, I wonder if that might be the problem. As long as everything is good and its nothing to worry about much I don't care, but i don't want the light showing up. Makes me thing something is wrong and I don't like that.
cams can make a vacuum change
Where is the purge
Originally Posted by elamplace
(Post 6264167)
(Post 6264167)
