Scheduled Maintenance Tables & Fluid Part #'s/Quantities
12 Attachment(s)
Attachment 298866 Attachment 298867 Attachment 298868 Attachment 298869 OEM Fluids 5 SPEED (W5N51) - Gear Oil API classification GL-4 SEA 75W-85 or 75W-90 - Diaqueen M/T Fluid - MZ313376 (1gal) - capacity 2.9 qts Attachment 298870 6 SPEED (W6MAA) - Diaqueen Super Multi Gear 75W-85 or exact equivalent - Diaqueen M/T Fluid - MZ313376 (1 gal) - capacity 2.3 qts http://i296.photobucket.com/albums/m...seypools/2.jpg Transfer Case - Mitsubishi Limited Slip Differential Oil (LSD) or equivalent - Diaqueen LSD Fluid - 3775610 (1 gal) - capacity 0.63 qts Attachment 298871 ACD Operating Fluid - Diamond ATF SP III - ACH1ZC1X05 (1 qt) - capacity 0.95 qts Attachment 298872 Rear Differential - Mitsubishi Limited Slip Differential Oil (LSD) or equivalent - Diaqueen LSD Fluid - 3775610 (1 gal) - capacity 0.58 qts Attachment 298873 Mitsubishi Coolant -MZ311986 (1 gal) Attachment 298874 Mitsubishi Brake Fluid -DOT 3 -MZ311987 (354 ml) Attachment 298875 Mitsubishi Power Steering Fluid -ACH1ZC1X04 (12 oz) Attachment 298876 Oil Filter -MZ690116 Attachment 298877 Timing Belt Kits - https://www.evolutionm.net/forums/mi...ce-update.html |
Nice. Anyway we can save this as a pdf file?
Very helpful, thanks.
added fluids
awsome! now when some one go to buy a used evo they know what to check/ask the dealer.
Is it possible to know the list of websites where we can order these fluids/oil?
Man why did you have to put this up? Now i know everything i missed 5k ago :eek: and now i have to go do it :lol: thanks for the right up {thumbup}
Originally Posted by djslik408
(Post 6679149)
good stuff here.
thanks man
Questions about oil, book says 10w30 but i hear different people use 5w30 also which is better? and If i use a different oil..say amsoil instead of the mobil 1 it says to use will the world keep turning? also i need 5 quarts right?
Great thread
Thank you!
Originally Posted by Skott2k
(Post 6743692)
technically you need 4.5-4.8 qts...if you run the larger oil filter you can add the full 5 and be right at the full line |
Thanks
thanks a bunch for this, you saved me alot of time researching what trans, diff and acd fluids I needed and where I could get them. Went to mitsubishiparts.net and they had everything in stock.
