-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Headlights Randomly Don't Work? (https://www.evolutionm.net/forums/evo-general/406020-headlights-randomly-dont-work.html)
kyoo Mar 11, 2009 07:46 PM
Have any of you come across this before? I am running an HID kit, but I have been for the past 2 years. The headlights randomly won't come on. I say randomly because it has done this once before, and then after the car had sat for a while and I just tried turning the lights back on they worked. I had thought it would have something to do with the HID's but both of them don't turn on at the same time.
Any suggestions?
kyoo Mar 11, 2009 09:39 PM
bump..
sonicnofadz Mar 12, 2009 12:22 AM
Which HID kit did you purchase? Where did you purchase it? What bulbs are you using? If you answer any of these questions with Ebay, then you know where you went wrong. Otherwise, check your connections, and make sure excess moisture is not making it to the bulbs or ballasts.
2.0Ldoom Mar 12, 2009 06:29 AM
I bet the ballasts are crap, as stated above ebay HIDs are a gamble at best.
kyoo Mar 12, 2009 07:05 AM
IIKDO, from a vendor on the site. I thought maybe ballasts but both when out at the same time.. what are the common connections I should be checking?
Have had them with no problems for about a year and a half - I just don't get why both wouldn't work at the same time unless it was some sort of connection issue
J8dailo Mar 12, 2009 07:19 AM
i say it could be the headlight switch...i worked on some toyotas which the headlight randomly wont come on sometimes..
JJsEvo8 Mar 12, 2009 07:24 AM
Check fuses as well..
kyoo Mar 12, 2009 07:25 AM
Could it be fuses if all of the other electrical components in the car are working?
lol where is the headlight switch? I'm really not good with electrical things
