Car won't start..
My next post in my series of issues!
I don't really know what it can be at this point.. Over the last few days I've been trying to mess with my car, to see why it won't start.. The cars not turning over.. I got a new battery with a charge on it, so its not the batt. It's not an alternator problem, since the battery has charge and crank power.. and I can't jump it. I thought it was the starter, but I replaced it with a friends (Nils) and it still won't start.. I checked the fuses and they all look fine.. The car itself doesn't crank at all when I turn the key.. just silence.. and my fan kicking on.. What the heck could the problem be? :*( |
put a ratchent on the crank pulley turn it over by hand see if it can do that (testing if the motor is seized) also try a push start and get back to me
Originally Posted by TyeVO
(Post 7114399)
*edit* Also, if engine was seized, wouldn't it at least try to crank up but not turn? It's not cranking at all.. |
not necesarily. it could not crank at all if it was seized. the starter would attempt to spin the flywheel but cannot overcome the motors resistance to move (seizure).
but i am gonna have to guess that ur motor is not blown. are you gettin power at your starter? have you bench tested the starter? does the vehicle make any noises when attempting to crank? like relays clicking...? |
Take a look at the top of your clutch pedal lever. There is a push style switch that the lever pushes against in order to start the car. You may have bent the bracket holding the switch.
Have you checked your ecu?
clutch sensor could be broken
(Post 7114515)
Originally Posted by EatSleepBoost
(Post 7114503)
Originally Posted by boscoyo
(Post 7114511)
Originally Posted by EvoHung
(Post 7114512)
(Post 7114515)
(Post 7114519)
+1 now that i read this persons post. im used to working on automatics at work and didn't think of this
Take a light and flash it to the top of the clutch pedal lever and you will see where the lever meets the switch when the pedal is pushed in. The switch is black and there is a blue piece of plastic holding the switch to the bracket. Make sure that when you push the pedal, you can see the switch lever go into the switch. If no contact is made by the clutch lever, bend the bracket until it makes contact.
+1^ maybe its bent, hopefully its an easy fix.
(Post 7114568)
:lol: :beer:{thumbup}
right on bro glad to ssee your back up and running
Thanks soooo much! it's been days.. :)
| All times are GMT -7. The time now is 09:43 AM. |
