-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   WHY does my evo shut off when the AC's on! (https://www.evolutionm.net/forums/evo-general/428850-why-does-my-evo-shut-off-when-acs.html)
03evokid Jun 21, 2009 07:54 PM
When I put the AC on and and im driving the car gets really sluggish. And then when I push the clutch it when I come to a light it just shuts right off. And if its on the car wont even start. SOMEONE HELP i live in GA and its like 103 out everyday
unsungboxer Jun 21, 2009 07:59 PM
hmmm, this is probably something that needs to be properly diagnosed, but here goes:
The AC adds load to the engine when it runs, the ECU should bump up the idle to compensate for this. If your car is having trouble idling due numerous reasons, the added load of the AC could cause it to die.
My first guess would be some sort of vacuum leak. This could be a loose fitting, or a hose that came unplugged. It could even be a blow off valve that isn't sealing properly. If this is occuring, you would likely notice your car having rough starts, rough idle, and sometimes sluggish acceleration off of idle, esp when cold.
I have also seen engines die when the fan from the AC/Radiator come on, usually happens with an open-element filter positioned too closely to the fan.
Thats all i have off the top of my head. Good luck!
03evokid Jun 21, 2009 08:02 PM
Well i have a AEM intake. And stock piping i had a stock BOV now i have a blitz bov still is doing it! i dont think there is any leaks anywhere i guess im goin to have to do a check for them
dunk186 Jun 21, 2009 08:02 PM
Any mods?? Mine does the same thing, but I know it's cause I need to be retuned
03evokid Jun 21, 2009 08:07 PM
Hks 280s
aem intake
epm dump
255 fuel pump
twindisc clutch with lighter flywheel
manual boost controler!
Adam@MMS Jun 21, 2009 08:17 PM
Bigger cams can do that to you. Probably not your problem but I thought I would mention it.
Gumby56 Jun 21, 2009 08:38 PM
bigger cams for some reason dont pull vaccum and once vaccum is low call will stall out ... for instance my buddy has 280s and and its pulls very little vaccum .... so basically it may be cause you need to get a better tune to compensate for huge cams
03evokid Jun 21, 2009 08:39 PM
hm tru im just on a street emailing tune!! I think i might take u up on this and start saving for a better tune i guess!!
GreedyE8 Jun 21, 2009 08:43 PM
This same problem happens to me, only my car doesn't die. It just idles very rough and at a very low rpm
Boricua_Evo Jun 22, 2009 08:43 AM
Is your BOV recirculated or venting towards the Air? Also your AEM intake should have have a smaller pipe for the recirculation of the BOV if it is not covered properly it, your stalling can be the cause of that as well...
Just throwing out some options bruh! GL
yahu Jun 22, 2009 08:52 AM
So did this just start? Have you installed anything recently, such as the bigger cams? What about the email flash, did you just do that? You most likely need a good tune to sort this out if it isn't in fact a leak somewhere.
03evokid Jun 22, 2009 09:06 AM
well ijust got the bov and it was doing it with the stock one b4.. And stated with the cams bc i put alot of stuff all in then got the tune and it started
Boricua_Evo Jun 22, 2009 09:17 AM
Hmm... interesting, please let us know when this gets fixed and what you did to remedy it. As others have mentioned check that tune, over the email tunes can be a little iffy!
1d10t Jun 22, 2009 09:18 AM
I too live in GA. Its hotter than friction from between a fat girls thighs.
Hey man, could be your tune for idle with a/c on n ecuflash!
ps dont post this issue on IA :updown:
Live4Redline Jun 22, 2009 09:20 AM
I agree... look at the tune.
