Ok, so here's a question
I drive my car like its ment to be, i try to take care of it, only 3k miles on it so far and 2 oilchanges (one at 80miles and 1 at 1500 miles along with a tranz fluid change)
anyway here's my question, i know how bad it is to drop the clutch on an AWD car. but babying just smokes the **** outta it (which ive done about 6 times, not actualy 'seen' smoke, but it just smelled bad) I'm wondering if i do a hard drop from about a 5mph roll and the tires dont kick loose, is that really as bad as from a stop? seems like the shock to the system would be a lot less (in my head anyway) of course its better when i break the tires lose because then its the tires that are getting abused and not the drive train / center diff anyway, i want ta get a feel for how hard i can drive and not totaly abuse the drive train (dont care to much about the clutch, its replaceable..) and im only driving like this maybe once a week, the rest of the time its to and from work anyway, thanks for any input.. (*totaly stock for now, waiting till summer to do mods*) |
mitsu is know for good trannies. you shouldn't be worried so much about the transmission unless you plan to get a better clutch. if im not wrong, i think the clutch is made to be the weak point of the whole transmission system..
so dropping the clutch is fine?
a guy in a red evo up here broke his center diff (im guessing from launching all the time) I dont want to break anything from dropping the clutch, i try to do it from at least a 5mph roll (if that helps or not i dunno) I really like dropping it while im goin about 15 around corners and kicking at least the rear, sometimes all 4 tires loose :D I do (or did, when the weather was good) a lot of AUTOX |
I hammered my friends Evo quite a few times, spinning all 4(too fun for words.) To make a long post short; His clutch is pure ****, I would not go too hard until you can replace that clutch. The tranny is solid, so unless you dump the clutch from a stop at every light you come too(Obviously not recommended), it will hold up to quite a bit of abuse.
Up to you though. The clutch is afterall covered under warrenty, its just the headache of having to get the car serviced, thus decreasing your fun factor. |
I was under the impression that the clutch is a "wear and tear" item.
Originally posted by LSNYC Up to you though. The clutch is afterall covered under warrenty, its just the headache of having to get the car serviced, thus decreasing your fun factor. |
Nope they wont cover a clutch, only way they will cover it is if it was a defect from install , like botls not tourqued down properly or missaligned packs. If it is glazed worn or anything like that they wil not cover you.
I dunno if this is the equivilant of dumping the clutch, but I do slip it pretty fast and then my tires spin for like half a second, I grip and I'm off. I usually dont get clutch smell when im doing it liek this, but what usually happens is im probably going ~5mph when my car engages from a dead stop.
| All times are GMT -7. The time now is 07:10 AM. |
