Car won't turn over.
Car cranks but won't turn over... failed fuel pump?
It could be a ton of things. Did you scan the car for any codes? |
AIR FUEL SPARK. Eliminate each problem to pinpoint it.
Does it try to start? Is the starter turning weak? Is there spark? YES OR NO? |
How can I check for spark?
It cranks until the battery slowly starts to die. |
Im guessing you can remove one coil, put a spark plug in it and let someone start the car and see if it sparks.
Take a plug out and put the boot back on it (with the wire, not coil pack) hold it against a bolt on the valve cover or something and have someone crank it over. Look at the electrode and see if u got spark. Good luck!
okay so theres no spark.....
Is it a stock motor? Built block?
Check crank and cam sensor next. |
Originally Posted by binh
(Post 7832347)
Check crank and cam sensor next. Changing the plugs won't help?... stock motor but I have cams. |
Dead coil pack?
What ohm range should the coil pack read...
what OHM range should the coil pack be set at on the voltage meter??!?!?
| All times are GMT -7. The time now is 12:48 AM. |
