HELP! Car Won't Start!
okay so here's some quick background info:
last week i flashed my ECU with an old tune from my previous Evo, but i forgot to save my current Immobilizer code. i ended up disabling my immobilizer and my car started up fine. my current problem: i drove my car to class and after i got out of class (6 hours later) i tried to start my car and it wouldn't turn over. i checked the fuses and my battery is only a couple weeks old (Optima Red Top). i tried to reflash my ECU, but it won't let me read/write anything. it just says "no response to any known code". i tried using ECU Unlocker, but that didnt work either. it was saying something like [FFFF] and then [FOFO]. then it would say "no response to any known code". i have no idea what to do right now. does anyone have any thoughts? |
Battery. IX especially will lock you out if they see low voltage. Basically they don't want you flashing if the battery is about to die. Put a jump box on it and ecuflash should be working again. does it even try to crank?
yeah it cranks perfectly. i actually recharged my battery to full and tried to use ECU Flash and it still didnt work. i tested the Tactrix cable on another friend's Evo IX and it read his ECU with no problem. i'm getting a new ECU tomorrow. maybe mine just turned into a brick.
Try disconnecting the battery for a while, then retry your efforts.
yeah i'm gonna try to reflash my ECU while my battery is on the charger.
figured it out. fuse #8 kept blowing because of my front o2 sensor wire was grounding out.
| All times are GMT -7. The time now is 09:03 PM. |
